Sony Playstation 3 (PS3) Console Logo
Posted on Jan 08, 2010
Ps will not go to menu screen
When i turn on the ps3 it just goes to the intro screen. it will not cycle to the menu screen
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
137
Points
My ps3 has the same exact problem. The sony intro screen loads but the menu will not come up. I have never played ps3 online, only use it for games and movies. Anyone know what's wrong?
4helpful
I have a playstation 3 system that worked for 1 day & the next time i attempted to play it,it did nt go past the initial playstation intro screen.The screen is grey with the playstation wave symbol...
Ok, follow these steps to cure your problem. Warning, you will lose saved game data!!
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you press it, then beep 5 seconds later and then once more another 5 seconds later and turn off. Release the power button.
Step 3. Press and hold the power button. It will beep once when you press it, again 5 seconds later and then 2 quick beeps together. When you hear these 2 beeps release the power button
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then continue to the next step
Step 5. The options menu will display. Select option 5 "Restore PS3 System". The PS3 will re-install the software required and restart. Hopefully this will solve your problem
Hope this helps and thank you for using FixYa.
2answers
My playstation 3 will onoly go to a black screen,
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
If after trying the above options and it still does not solve the problem, then maybe the lens is weak and that's why it cannot read any disc.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck.
When I push and hold the ps button on the remote the screen goes black and flashes
well as cookies.
4helpful
2answers
Ps3 freezes and screen goes fuzzy
Try to restore file system on your ps3.
Follow this guide.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when t turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Today after playing a game I moved the console to another tv and now the ps3 will start and play the short intro but it will not continue to the menu screen where you can select video,internet,dvd ect......
try using a different cable to connect the ps3 to the tv it might be looking for a different type of cable if this works you can set to look for the right type of cable under screen settings
It turns on but no menu appears. just have the intro screen saver
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
2answers
I put in a BluRay movie and it shows on the menu but when I hit X to play it, the screen goes black and will not play. PS3 games are hit and miss.
It sounds like you are having a firmware problem. This is common with blue ray. You will have to go to the ps3 site and download the firmware upgrade for your system. I think you can upgrade automatiacally if your ps3 is hooked up to the internet. Go to menu settings and look for updates for firmware or divers...
Please don't forget to give very good ratings, they are important
5helpful
When I turn my PS3 on, my background screen appears but nothing else loads, not even the numerous areas (Settings, network etc.) all that appears is an icon in the upper right hand corner saying "Press the...
you can try doing this cuz i had the same problem till i did this...Access the PS3 recovery menu
2. Hold The power button down; The system will turn on and turn off once again.
5. You will be promted to plug in your controller via usb and then hit the PS button
..I did this and i got my ps3 Back !! :)
be patient and wait for those beeps.. they are important
Hi when i turn on my ps3 corrupt data comes up on screen and when my ps3 trys to fix the problem it just goes back to the start again i cant even get into the main menu its 2 years old was kept like new i...
1. Plug in controller
2. Have system in standby mode (red light)
3. Hold down power button for a full cycle (will turn on and back off again)
4. Hold power button again will hear 2 single beeps then a double beep.
5. As soon as you hear the double beep immediately remove your finger from the power button.
6. Hit the PS button on controller when it tells you to
7. Go to ONLY option 3 (restore)
8. WARNING: select any other option and you can wipe out everything ONLY USE OPTION 3
9. Follow on screen prompts
Try this and get back with me, I will look into it for you.
Ps3 wont load games up
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
• Restart System: Restarts the PLAYSTATION 3 System.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
