Motorola Mobility RAZR V3 Logo
Posted on Jan 06, 2010
I need to download pictures from phone to my PC ....I have an USB cable ...I tried with the bluetooth option...didn't work..
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jan 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
608
Points
Have you checked your USB cable? Is it working properly? Problem might be with your cable........ Or your system had not installed the device required to do such work.........
How to download picture from cellphone to pc
If I understand you correctly you wanted to transfer your pictures from phone to pc. To do this please see steps below.
There are two ways to transfer the images from your phone.
A. Using the Bluetooth Feature.
(Please note: Your PC should have a bluetooth capability to do this)
1. Enable the bluetooth device of your phone. Settings -> Connectivity -> Bluetooth
2. Go to picture viewer and select a picture and press the "Option" soft key 11_23_2011_5_12_27_pm.gif.
3. Select "Send" and choose sent via Bluetooth.
4. Your phone will scan available bluetooth devices and you must select the name of your pc.
B. Using the USB Method. This method is more practical and faster way to transfer images from your cellphone.
1. You must have a microUSB v2.0 cable. (This may have been included in box of your phone if not you can purchase this separately). Please see screenshot below.
2. Download and Install Samsung PC Studio Software. Click here to download. (when the download screen pops up just hit "Run".
3. Connect the USB adapter cable to your PC. A USB icon 11_23_2011_5_24_34_pm.jpgdisplays on the screen when an active connection is established.
4. In Idle mode, press Menu ->Settings -> Connectivity. Select USB Mode and press the Select soft key or the key. Use the Up or Down Navigation key and highlight this option:
• PC Studio: is set to launch PC Studio as the default application
when a USB connection is detected.
Press the Save soft key or the key
5. Open the PC Studio program, usually it will create an icon in your desktop.
6. Select Manage Files and it will give you the list of folders you have in your phone.
For more detailed step by step instructions on how to transfer images from your phone please click here.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
tip
How to Transfer Pictures or Video from your Cellphone/Mobile to your Computer
With the increasing quality of Cellphone camera's , more and more people are wanting to copy their pictures from their phone's to their computers.
There are basically 4 ways to accomplish this.
  1. USB Cable
  2. Bluetooth
  3. Card Transfer
  4. E-mail
# 1 USB Cable
One of the most convenient ways to transfer your pictures is to use the USB cable if your phone was supplied with one. If your phone was not bought with a cable , you can purchase the cable from the store where the the phone was bought.
You will usually also need the manufacturer's software like Nokia pc suite for Nokia phones which can be downloaded from the website of the manufacturer. Here is a list for the most popular phone brands sites.
Nokia
Samsung
Sony-Erricson
Motorola
LG
Many phones also support the option to use the phone as a flash drive so to speak. When you insert a cable , the mobile would typically ask in what mode to use the cable in for instance : Print , Storage or Nokia mode. If you select the storage mode , you may transfer your pictures from the phone the same way you would from a flash drive.
# 2 Bluetooth
If you are using a laptop or bluetooth enabled PC , using bluetooth can also be a handy way to transfer your pictures. To do this , enable bluetooth on you computer and from the taskbar , right click on the bluetooth icon and select recieve a file.
Then on your phone , go the the picture or video you want to send and select options and send via bluetooth. This will vary from phone to phone , so look around for the send with bluetooth option.
Your phone will then search for a computer in range and once you have found your computer , hit the send button.
The transfer will then take place and your computer will ask you where to save the image.
# 3 Card Transfer
Most phones these days have a removable memory card. This is a easy way to transfer a large amount of content from your phone to your computer.
Simply remove the SD or Micro SD card from your phone (refer to your manual) and insert it into a external card reader or your laptop's built in card reading unit.
You may also need a micro to sd converter which can be bought either with a micro SD card or separately from most chain department stores.
You will then be able to transfer the content like you would from your digital camera.
# 4 E-mail
If your cellphone supports e-mail and it is set up , and you only need to transfer one or two pictures , e-mail can be very helpful.
To do this , go to the image you wish to send and in the options , select send via e-mail. This option differs between brands and models so check your manual. You can then simply send the picture to your PC e-mail address and retrieve the image from there.
Please remember to rate this tip if you found it useful.
Kind Regards
StephanSA
on Feb 24, 2010 • Cell Phones
3answers
How do you download pictures from phone to pc?
First you need to install the drivers of your mobile .
Then if your mobile has bluetooth , and your PC has bluetooth too,you can do it through bluetooth.
If you dont have bluetooth ,you need the PC usb cable of your mobile and connect your mobile tp your
PC via usb cable.
1helpful
2answers
I am trying to download pictures from my galaxy s fascinate phone and my computer is asking for a disc to be inserted to set it up. A disc did not come with the phone.
Most cell phones today have a few ways of getting pictures, music, videos to your PC/Laptop.
1. Via USB cable - This method usually requires drivers from a CD that came with your phone or can be downloaded from the manufacture's website in order for your PC to recognize your phone when you connect.
2. Via mini SD card - Most phones now have a mini SD slot where you can add more memory to the phone for pictures, music, videos, etc. Usually found attached on the side when you take the battery cover off. It will be a small black chip about the size of a finger nail and to remove it, you simply press it in, then it should release. If you have a memory card reader/slot on your PC/laptop, the mini SD card usually needs a separate adapter to make it fit into a standard SD slot.
3. Via Bluetooth - This requires your PC/Laptop to be able to connect with bluetooth devices. You must pair the PC with your phone first so they can communicate with each other. While using your phone, pick the file (picture, music, video, etc) from your phone, select Options, and send via bluetooth.
How do you download pictures from phone onto computer
You can download picture from phone through usb cable or through the bluetooth. Just connect the usb to the computer and it will dictect the usb cable immediately. Just click on open folder and copy the pictures and paste them into the computer. For bluetooth you will need to add your phone to the computer through the bluetooth settings, then mark the pictures your want to copy to the computer and press option then copy. This will transfre the picture to the computer. Thanks
7helpful
2answers
How can I transfer pictures from my SCH-U350 to my computer?
1. Email them to yourself. Cell Company charges you.
2. Wireless Bluetooth on your phone, to wireless Bluetooth (small USB Bluetooth you buy) to your computer. Wireless Bluetooth to wireless Bluetooth. Free except onetime purchase of USB Blutooth for your PC. This is IF you phone supports this.
3. USB Data Cable (I paid $2.60 for mine over internet this past week, thecellshopdDOTnet) AND software such as Datapilot (or others) on your PC. The USB Data Cable plugs into the same place as your power charger, & will also charge your phone as well as transfer pictures. Make 100% SURE FIRST from the software vendors that they have YOUR phone in their list of supported phones!!!!
How to export pictures from mobile phone scp 2700 to pc. Do I need a special software?
Hi friend,
I think you don't need a special software if there is an USB cable and USB interface, you just need to connect the mobile phone to the pc by the USB cable.After your mobile phone be recongnized by the pc,you can transfer the pictures to pc.
Or you can download a bluetooth software to your pc,then find the bluetooth in your mobile phone,then you can connect the two bluetooth,and transfer the pictures.
Welcome to ourwebsite:www.1010store.com to get much solutions about other problem of mobile phones. Good luck!
1helpful
2answers
I want a software to download photos from my cellphone to my Pc
Didn't you get the software CD (PC Suite) when you bought your cellphone? PC Suite, Data Cable, Headphones, all come as free accessories. If you don't have it, download the PC Suite of your phone model and use the file transfer option. Alternately move the photos to your memory card, take out the memory card and insert it in a card reader. Connect to USB port and move the photos to a drive or folder in your pc. You can use copy-paste or cut-paste (to free your phone memory).
91helpful
9answers
How do I download pictures from my LG VX5500 to my computer?
The simplest way to do this is to:
  1. Download and install BitPim from www.bitpim.org.
  2. Start BitPim
  3. Tether the phone to your PC with a standard micro USB cable (like the one that comes with a Droid or newer BlackBerry). BitPim will autodetect the VX5500.
  4. Go to the View menu and select "View Filesystem".
  5. Browse to the brew / mod / 10888 folder, right-click on each jpg file in the right pane, and select "Save" to save them to a folder on your computer
Unfortunately, you need to save the pictures one by one, so if you have a lot of pictures it will take a while. But hey, it's free and you're sticking it to Verizon.
If you don't have a cable and want to use BlueTooth instead, refer to this blog page (thank you to this gentleman, by the way): http://www.adrianandgenese.com/blogger/2009/01/28/uploaddownload-ringtones-and-wallpapers-to-your-lg-vx5500-using-bitpim-and-bluetooth/
2answers
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
