Has half of the screen clear while other half has vertical colour lines that changes intermittently to clear picture, total black and back to the colour line. Same half at all times. Can you help
do the proper isolation proceedure and try unhooking the Su from the SC board to see if you then get a normal picture all the way across the bottom half of the screen? I am assuming the Vertcal extends extends all the way from top to the bottom of the screen?
I had the same issue. I could get the tv to work intermittantly by pressing on the boards while playing. This points to bad solder joint, so I resoldered every molex plug connector, and it nows works like a charm.
With half of the screen working, and with a Plasma tv. I will look at the driver board as being bad. Take the back cover off, the driver pcb will be at the top or bottom of the set. They are only about 2 inches tall and will cover most of the lenth of the set (2 boards that run end to end). The board that is on the side of the tv that is bad is the bad board. Replace that board or have a tech replace it.
check all inputs on tv ,also check if menu on tv is working ,make sure lines arent being produce by another source, cable box etcc..If menu and or OSD are affected .Then there is a good chance you have lightning damaged some where in signal section on tv .
