Question about Vision HDV-42P2 Television
Panasonic tv has a black square on the tv screen
Posted by Michael Krous on
    Top Expert:
  • Vision Master
  • 76,455 Answers
Check whether 'CC' function is ON. Refer the user manual for details.
Posted on Nov 03, 2013
  • Ricardo
    Ricardo May 23, 2020
    Thank you, your solution fix my tv problem.
A BLACK SQUARE APPEARS IN THE MIDDLE OF THE SCREEN HOW DO I GET RID OF IT
Hi Tony
You`ve mentioned that ON CERTAIN CHANNELS THE TV WORKS FINE, so your trying to say that not all channels THE BLACK SQUARE APPEARS IN THE MIDDLE O THE SCREEN... my be that black square is generated from the broadcast center. may be your unit is good. let me ask you how many channels that your tv works fine..?
Jan 16, 2014 | Panasonic CT-34WX52 34" TV
When I turn on the TV a black square appears & covers almost all of the screen...What's wrong?
hi,
Go to the menu of the tv. Serch for CC (Closed capion option) and change its setting to OFF.
Or press the CC button on the remote repeatedly to select CC OFF.
OK
Sep 09, 2011 | Panasonic AG-520G 20" TV/VCR
Panasonic 42'in viera no pic, just thick,square, white border
Unplug it, wait a minute and replug it. Also check the settings and see if it changed.
Jan 04, 2018 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Have a black box in the top left corner of tv how can I get
check and see if your tv has PIP (picture in Picture) which you turn on and off with the remote. If you do you have PIP turned on, but not set to any station.
Nov 30, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
We have 2002 panasonic large screen tv. It has a large black square in the middle of the screen. Is is repairable
Yes and usually by the customer - turn off the closed captioning (CC). Look through the on screen menu (setup menu) to find closed caption and select it to off.
Oct 22, 2009 | Televison & Video
Black square in center of screen - no "closed caption" solution
Here are the steps from the owner's manual:
1. Display MAIN MENU. Press ACTION key on remote.
2. Display SET UP TV screen. Use arrow keys to select TV icon and press SET key.
3. Display CAPTION screen. Use arrow keys to select CAPTION and press SET.
4. Select CAPTION MODE. Use arrow keys to select CAPTION MODE. Press SET to cycle through caption settings until it says OFF.
5. Press ACTION key three times to return to normal screen.
You can download the manual from Panasonic here if you need a copy.
Apr 03, 2009 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Big black square
this is pip,,,if you can noy find botton on menu...unplug 5 min....return pkug to wall socket push and hold power botton for 5 seconds....this should fix it!
Dec 10, 2008 | Panasonic PT-47X54 47" Rear Projection...
47 inch Pabasonic Project T.V.
This could be part of the text mode, which has to do with the caption. Check and see if it's turned on.
Aug 12, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Black Square in center of screen
I was about to go buy a new tv. I'm blaming it on the cat, thanks!
Feb 06, 2007 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Black Box over screen when playing DVD's
scrool your tv with the remote and go to caption turn off caption and the black will disappear the remote lock the tv in text 1
Jan 06, 2007 | Samsung TX-R2735 27" TV
Televison & Video Logo
488 people viewed this question
Top Vision Televison & Video Experts
Marvin
Marvin
ray gallant
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
