Question about Philips Televison & Video
Phillips 42'' Plasma vertical bar on screen
Have 42'' Phillips Plasma TV. Recently a vertical bar approx. 9''x3'' appears intermittently in middle of screen. Vertical bar is not solid but scrolling lines resembling interference. Last night, screen went completely black and picture re-appeared once TV was turned off and then on again.
Posted by KARDEB on
Larry
  • Philips Master
  • 2,812 Answers
Y sus board issues
Posted on Feb 07, 2018
5 Related Answers
Anonymous
SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
Posted on Oct 31, 2007
Anonymous
SOURCE: HDTV 42 inch Plasma Sanyo model DP 42746
the picture is very dark
Posted on Jan 24, 2008
Anonymous
  • 6 Answers
SOURCE: Vertical black bar down the middle of hitachi plasma tv
The tv is shot. This occurs when pixels on the top row of the screen break, which blocks current from moving through the rest of the pixels in that column. But don't worry this problem is common and is covered in your tv's warranty.
Posted on Jan 05, 2009
Anonymous
  • 6 Answers
SOURCE: 42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Posted on Mar 03, 2009
Anonymous
  • 64 Answers
SOURCE: samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
Posted on May 25, 2009
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
May 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Intermittant vertical black bars on 42HP84
there is a good chance that I can solve your problem, although for me and others this problem usually shows itself as black bars that go from top to bottom, not just half way.  go to the following link and read the entire thread, it is very good info.  I have done this and it worked perfectly on a gateway plasma, but it also works on numerous others.  there is a guy on ebay that sells a fix for $80, and it appears to be exactly what i did.
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Apr 03, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
Vertical bar on Daewoo Plasma screen
try this, can't hurt!
st
Sep 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
Aug 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Black Vertical Bar
It will burn into the screen overtime. The Akai units have a resistor on the address board that feeds the PDP that usually has a crack in the solder on one or both ends of it. There are about 4 address boards that are right below the panel itself and the suspect one is the board right below the line that is appearing. Have someone with solder skills repair it.
Jun 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Fault in Plasma display screen
Depending on the location, it could be the Logic Main Board, or a buffer board
Mar 06, 2007 | LG RU-42PX10 42 in. HD-Ready Plasma...
Televison & Video Logo
Top Philips Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
