Everything was working fine until we decided to clean our range with cleaners. We tooks out all knobs and cleaned them thoughly. When we plugged in range, it is displaying F7 on all screens and it is beeping. Please help!
F7 for a Fridgidaire Range indicates a failure with the electronic Range Control (ERC). Unfortunately when these fault codes pop up, the electronic boards must be replaced. The part number for yours is 937801 and costs about $190. Is it possible you may have gotten cleaner on the board or possibly shorted out the buttons? Is your range still covered under a warranty? Double check your paperwork and see if the electronics are covered for an extended period beyond the normal limited warranty you get when you purchase a new appliance. Post back with comments and/or questions if you wish to repair the range. I hope this helps you.
or greater.
Error codes are on page 61 section 5-1
Please Rate This Solution, Thank You! Sea Breeze
The F7 code has come on several times, and after a while it does go away and work perfectly again. I always thought that it was caused by moisture shorting the connection. I was baking dog biscuits and there was steam coming out of the vent, which it located right under the control for the left back burner. All the burner lights were flashing and beeping, but after about 10 minutes it went away and everything worked well.
