Whirlpool GT4175SPS Stainless Steel 1200 Watts Microwave Oven Logo
Posted on Dec 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
In order to start the microwave i have to push the door
Garth Jackson
Level 2:
Scholar:
  • Expert 93 Answers
  • Posted on Dec 29, 2009
Garth Jackson
Expert
Level 2:
Scholar:
Answers
93
Questions
Helped
33391
Points
232
The door switch is loose or fualty you can adjust the switches first to see if it hase just moved if this does not work then replace it.unplug the unit and remove the cover panel look between the controll panel and the cavity on the back of the front panell you will see two or three switches the (GREY or BLACK ) look for the retaining screw loosen slightly and adjust if this does not work the take notes of the wire positions etc on the switch get a new on eand replace close unit plug and play
Pushed in spring loaded latch on the microwave. Need to pull it back out. Spring is not broke.
No, you don't have a new problem to fix, and consider yourself and anyone else that uses that microwave lucky.
Depending on where that crack is you need to know that the screen like structor in the door is actually a choke to stop and microwave energy from escaping, including anything around it. They are designed to stop any stray microwave energy from leaving the microwave. This could harm you so if it is anyware near that door choke, if I were you I would order another door. The same goes for the gasket around the inside of the door it to is a choke.
You are also causing yourself some potential danger because the door must never be circumvented to keep the light on or off because if you should accidently start the microwave then you will have problems.
Sharp r-509fw Keypad problem?
You need to replace the control panel, the panel is all one piece buttons and all.
1helpful
When I set the timer and close the door, the door latches fine. When I push the start button the timer starts to countdown but the microwave doesn't start. If I push the door release in about 1/8 " ,...
If your model number is in the Sharp R-1500 series, then that's a problem with the bottom door switch or its mount.
See these files:
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
http://207.234.249.73/mwd/doorsw.txt
2answers
When trying to use the microwave it displays "door" and will not operate
More than likely its your door interlock switches. Try pushing in, up or down and see if it works. If it does it's your switches
I have a JES1358 Microwave
This is probably the top or bottom door switch or its mount may be loose or broken.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
It's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or elsewhere which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
Over the counter microwave will start on first attempt
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
I have display, but no lights, no fan, no power!
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
Glad you found the "mini-manual". It's very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
1helpful
Microwave door won't open when I push the button!
check door open mechanism, any broken change the mechanical parts,
Microwave blows fuse
The most common suspects are the high voltage transformer and the magnetron. It's also possible you have a flaky door switch or loose door switch mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
