20 Most Recent DCS CMO-24-SS Convection/Microwave Oven Questions & Answers
If its not heating.The the possibility is faulty heating element.There is a heating element in the unit which gets short and needs to be replaced.If the unit is not heating then turn table will not turn.But other cause of turn table not turning is.There is motor which spins the turn table.if this motor is got faulty then turn table will not turn.but as per the problem it seems like heating element is faulty . you can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
DCS CMO-24-SS... | Answered on Aug 08, 2010
If all appears to be running as its working but just no heat. Could be issue with magnetron. You could also have loose connections to magnetron or somewhere in high voltaged as well.
DCS CMO-24-SS... | Answered on Nov 25, 2009
the likely cause is the hotsurface igniter has failed. not exactly sure how to check the part but you can check it voltage is getting to the igniter. if you have voltage, it's probably the problem.
DCS CMO-24-SS... | Answered on May 28, 2009
You need to remove the bottom cover if it's an over the range model.
If it's a counter top type, there should be a cover over the turntable motor.
On many Sharps, the turntable motor cover comes as an unseparated part of the bottom cover and you have to use sidecuts or snips to cut away the little tabs which hold it in place. Then when you are done, you use a screw to hold the cover back in place.
All this is best done with the microwave on its left side with the door opened, and the turntable and support removed. (Power off, of course).
Once the cover is off, you remove the two screws holding the motor, pull the motor out, then pull ou tthe old coupler.
Install the new coupler with one hand, and push the motor in place. Jiggle the couple as you do so it will mesh with the motor shaft.
Once it's in, replace the motor screws, replace the cover and you are done.
DCS CMO-24-SS... | Answered on Sep 27, 2008
check door open mechanism, any broken change the mechanical parts,
DCS CMO-24-SS... | Answered on Mar 24, 2008
Replace. Microwaves are cheap.
DCS Microwave... | Answered on Feb 16, 2018
Either the magnetron tube or it's high voltage power supply have failed These are the two most expensive components to replace and it may be more economical to replace the oven than to repair it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
DCS Microwave... | Answered on Feb 26, 2015
What is your model number?
DCS Microwave... | Answered on Aug 20, 2011
Hi, if it has tripped the circuit breaker after a reset then it could be beyond a DiY I'm afraid.
It is most likely just a build up of fatty grease which is making the unit arch internally, this can be rectified by a technician quite easily but if you are unsure what you are doing you could damage it further still.
MY advice is unfortunately leave it to the experts, avoid calling out an engineer, look up a decent repair shop and take the unit to them as this saves a call-out charge. Then when you drop it off ask them for an estimate BEFORE they do the work as this pushes them to keep the cost of repair realistic.
Hope you take my advice, microwaves can be very dangerous if not repaired properley
Best regards
Lloyd
DCS Microwave... | Answered on Dec 15, 2009
A generic troubleshooting response would be...... if the burner won't stay on, either the igniter or the ignition module (or both) are bad. If the burner ignites and stays on but the spark module keeps trying to ignite, the module must be bad.
DCS Microwave... | Answered on Sep 14, 2009
strip door but first take it off mic
Microwave Ovens | Answered on Jul 16, 2019
DCS CMO-24-SS Convection/Microwave Oven Logo
Popular Tags
13 questions posted
Top DCS Microwave Ovens Experts
William Miller
William Miller
Colin Stickland
Colin Stickland
Tom Chichester
Are you a DCS Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
DCS Microwave Ovens
  • DCS Microwave Ovens
Most Popular Question
dcs cmo24ss 900 watt microwave not
  • Microwave Ovens
