The fault code is '19'. Counting the flashes to philips TVs are given in detail by the link given below.
These blinks are fault indication, and known as blinking
codes. From the number of blinks occur
at one time switch ON; you can get an idea about the faulty circuit stage
inside the TV. This will make repair
easy. For more information, check the link http://electronicshelponline.blogspot.com/ You can get details about the fault codes, blinking codes etc:
When I press the on button no picture but sound comes on briefly then shuts off followed by green light blinking once, then twice, then 3 times and the blinking sequence repeats over and over. Have tried unplugging tv overnight and plugging it into a different outlet. No change.
the tv powers on but no picture appears on the screen then the green indicator lite flashes 1,2,3 times pauses and repeats endlessly. There was no warning of an impending problem. i had watched a movie earlier that 2 hrs previous to the tv crapping out.
3,2,1, green lighht
I am having the same problem with my t.v. It is a phillips model 27PT6441 power light blinks repeatedly when turned on and no picture? Can you help?
I have the same issue. How do I fix it?
I have the same problem. The green light blinks 11 times and then a pause then three times, a pause, then two times a pause...one time a pause...and then starts all over again.
I have the exact same problem...
Hello. I've got the same issue on my son's TV. I had replaced thefuse a long time ago and now it's doing this...relays click then thegreen LED flashed three times, two times, then one long... Can someonesend me the info to fix it? Andy007? I've been told that there is arepair kit available for this known problem.
Thanks much,
Robert
