How do I get round a SafeBoot security system 3.3 screen which requires a password that I do not know.
Best way would be to give the computer back to the owner and ask them to enter the password... If you have no idea what the password is, I can only assume that this does not belong to you.
If you bought it this way, sorry to say, the only way to get around that is to format the hard drive and reinstall the OS, as SafeBoot is a form of Whole Hard Drive Encryption.
You may need to enter the BIOS and set the machine to boot from the optical drive first so that you can boot the recovery/OS disc, this is, if the boot function key (F12) has been disabled. Try pressing F12 at the POST screen (Dell logo) and see if the Boot menu comes up. If it does, you can boot the disc from there, without messing with the BIOS settings.
This happens when set you PC on Safeboot Option.
Follow the steps mentioned below to boot in normal mode.
1: Once you are in the Safe Mode, Click on Start and then Click on Run.
2: Type msconfig (you will see system configuration utility).
3: Click on Boot.ini tab and check for the Boot Options.
4: You will see Safe boot options check.
5: Uncheck it then click on apply and then then ok.
6: Now your computer will boot in Normal mode.
Once you reach the desktop you will again see the system configuration utility screen. Just check the option don
