20 Most Recent Dell PowerEdge 840 (becwmk1_2) Server Questions & Answers
using a DELL 13 year old server... 850 model.
REDUX #3, (im almost up to speed on YOUR GOAL)
you bought the wrong server, sure been there done that.
and discover to your chagrin that the SATA port
is useless for SAS new drives.
well it is. sorry.
not only that those 2 ports are slow, Intel ACH7 chips are Slow.
but so is that old Pentium inside.
omg some with CELERY chip dogs
https://www.dell.com/downloads/global/products/pedge/en/850_specs.pdf
i see that call SAS SCSI back 13 years ago
ok that cute, historically.
the CTO order new server had 10 choice on
just the controller (drive) with cables for data
power , backplane and cage, all missing in yours.
there is only 2 cures.
1: buy the dell parts missing in your server.
card + cable + sas cage (and matching backplane)
I bet only uses ones exist now,ask DELL that.
2: buy a cheap raid card, and flash it to HBA mode.
JBOD mode.
https://www.cnet.com/how-to/how-to-turn-old-hard-drives-into-one-large-drive-in-windows/
now some images
perc-v2jzpkvbuwxiggkcn1zz0rrd-3-3.jpgsometimes the limit, is firmware, or the driver
or simply , Dell didnt have 2+TB hDD to test back in 2005.!
reality of that fact.
Dell PowerEdge... | Answered on Apr 09, 2018
The problem that you are having is that the unit you are trying to upgrade is a SERVER, and not a desktop PC. There are notable differences in how servers are built. One is that they are not all that concerned with graphics and graphics performance, since they normally operate "in the dark" and are often accessed remotely. I did some research on the Dell site and saw a comment about your problem in one of their forums. I provide the link below. It should be informative.
Graphic Card not working in Dell Power Edge 840 Server
Dell PowerEdge... | Answered on Jun 14, 2015
Then you need to get into the BIOS of the PERC RAID controller and inspect the state of the physical/logical volumes. Reboot the machine and watch for the prompt after the PERC5/6 RAID controller loads it's BIOS.
Considering this a null issue given the age, though...
Dell PowerEdge... | Answered on Jun 13, 2015
Check your power supply or the power supply source (outlet or UPS unit) as well as the power cord. Your system power source is not at the correct amp, voltage and may need replacing.
Good Luck.
C2Solutions
Dell PowerEdge... | Answered on Feb 15, 2012
By using the os (Windows Server, UNIX, etc) it will ask during setup if you want to make this a domain controller. Remember, networks can only 1 primary domain controller (PDC) but many backup domain controllers (BDC) choose correctly as well....BDC can be promoted to PDC. PDC have to have a reinstall.
Good Luck
C2Solutions
Hello
This error mostly comes with the failure of processor fan, overheating of processor shuts down the system due to processor's protection. You need to check the fans and replacement is recommended.
Hope this helps
Dell PowerEdge... | Answered on Jan 31, 2011
Check both the POWER and the DATA cables between the motherboard and the HDD (Hard Disk Drive).
Remove them, and then re-insert them.
Try connecting the DATA cable to an alternate connector on the motherboard.
Remove the HDD, and connect it to another computer,
to see if the HDD can be detected on that computer.
If not, the HDD is the problem.
Dell PowerEdge... | Answered on Oct 27, 2009
It sounds like an overheating problem. The newer cpu's have a thermal shutdown sensor that automatically shuts down system if it senses a temp that is too high. Common solution would be to check your cpu/ chassis fan and see if they are working. If not replace.
Dell PowerEdge... | Answered on Dec 20, 2008
Computer not recognizing the hard drive. Look in BIOS to see if hard drive is listed. Reload system disc/CD.
Dell PowerEdge... | Answered on Mar 14, 2016
It could be a couple of things 1. the computer Cpu fan is not working or is clogged inspect it and clean or replace.2 The power supply could be bad
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
Dell PowerEdge... | Answered on Oct 01, 2014
www.hp.com/support
Dell PowerEdge... | Answered on Aug 18, 2014
Dell PowerEdge 840 (becwmk1_2) Server Logo
16 questions posted
Clive
Clive
Alun Cox
View Most Popular
PowerEdge Dell
  • PowerEdge Dell
Most Popular Question
new toshiba sas drive will not setup in
  • Computers & Internet
