Televison & Video Logo
Posted on Dec 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I selected 1080p.the screen says out of range and now i cant change it back.
Lee A.
Level 3:
  • Master 4,472 Answers
  • Posted on Dec 09, 2009
Lee A.
Master
Level 3:
Answers
4472
Questions
0
Helped
1083961
Points
12549
First of I need the make and model of what device it is you changed and need to change back. This is why you always want to check the specs of your tv and what it can handle first before changing the resolution settings. Once I have more information I can assist you further.
Thank you,
Lee
6answers
How do I change my LG 4k to a higher resolution.
It depends on your source video resolution. If you're willing to play in 4K, you can upscale your 1080p or 720p video to 4K resolution in advance. Here is the video tutorial:
After conversion, it will be played in 4K on your TV. Of course, it's all based on that your TV supports 4K.
Cant use source list
You have to go to Input and select and select HDMI. With the remote.
Edge to edge screen bumping to get more space on 5100 dell
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
My screen is little blurred . i cant see objects clearly in my screen
you can make changes to your screen resolutions and brightness in your computers settings or if your computers monitor is separate to your computer ie:desktop it might have tabs to make some changes to its brightness and resolution
click start control panel,display,desktop you can select a different desktop from the drop down list
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
hope this helps:
2helpful
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
How do i get it back to 1080p had it disconnectted for a while but it is now 480p
You can consult the manual to verify all of your settings.
Changing the screen resolution can be tricky...
If it is a setting in your television, it can be accessed by pressing menu on your remote.
Once in the menu, there should be settings for the screen or picture. One of these will allow you to select resolutions. (consult the above manual for exact navigation of the menu)
The other thing is, sometimes televisions change automatically between resolutions based on what signal they have received. In this case, it isnt the television that is the issue, but is the device feeding it the signal, such as a cable/sat box or dvd/bluray. Make sure to check those devices to make sure they are sending the signal you require (in this case 1080p).
With more information about the device from which the signal is coming, we might be able to isolate where the problem is.
Eg. if your xbox isnt set to high resolution, or if your cable box isnt set to 1080p, your television cant possibly display at that high of a resolution.
Flickering in the main PS3 screen with 1080p resolution
1080 i is what you run going to higher resulution causes that your provider is 1080i or 1080p
2answers
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Problem connecting HDMI cable
Hey there I don't see why your playstation 3 should be doing that other than the console being defective. Sony doesn't have this problem that often and actually this is the first time i have heard of such problem. Try making sure the the HDMI cable is connected at both ends all the way in and also make sure your Samsung is a 1080P which i am pretty sure it is and finally if you have a friend or another 1080P HDTV in your house i would try and see if your ps3 will support the 1080P feature. If you still have the problem even when you use a different TV then its the ps3 that is malfunctioning otherwise it would be your Samsung. Let me know how that turns out alright.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
