For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click
on wireless settings then enable WEP Security then add WEP code .It is
your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Thanks for using FixYa.
Ok. If you don't know your password. Then you will want to access the router and change the password. Here is the manual refer to page 14/78, and wireless settings are on p. 25/78
http://www.netwood.net/support/manuals/D-Link_WBR2310_manual_10.pdf
It is a very straight forward setup if you have any questions about the steps please let me know. Basically you just use your internet browser(IE,firefox,etc) type 192.168.0.1 in the address box use admin username and leave password blank. Then refer to the steps in the manual to adjust your wireless settings. If you have any other questions I will be more then happy to assist you further.
Thank you,
Lee
did you have the internet working on the router at all? Have you tried or considered hooking up a Ethernet cable straight to the router. Get it all set up that way then connect with wireless/ Also if you have to you can always reset the router back to factory settings.
To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
Like I said follow the steps and it is all pretty straight forward. Also most times. You don't even have to run the wizard. You can just click on the wireless tab and set up wireless and most times internet will work on router depending on your type of internet. If you have dsl their may be some additional steps to put in your user name and password for your dsl account.
Thank you,
Lee
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings. From the center screen, select your encryption type from under the Security Options heading If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router: Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Hope this helps don
THIS IS A SUPER QUICK AND EASY FIX!
Use an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
I have set up the router before, but i need help going through setting it back up again step by step... I have no idea about this stuff, and I'm unfamiliar with the terminology so it's helpful when the questions are as detailed as possible...and I'm confused about how I can set up wireless, when I need the ethernet cable to be plugged directly into the computer to be able to chat online. Please help...
just needing help getting generally set up, and wondering if I can just guess when it's time to put in a password?
Hello-
I got as far as this:
DHCP Connection (Dynamic IP Address)
To
set up this connection, please make sure that you are connected to the
D-Link Router with the PC that was originally connected to your
broadband connection. If you are, then click the Clone MAC button to
copy your computer's MAC Address to the D-Link Router.
but it will not allow me to move forward when I click on "next," nothing happens :(
