Sounds like the monitor is not getting a signal from the tower.
Do you have another monitor/LCD screen that you plug into your tower? That will tell you if the LCD is the issue or the tower.
If it is the tower that is at fault, then you need to try and figure out if your video is separate from your motherboard. Hopefully it is separate, that way you can get that replaced.
If not, then it means that your video card is integrated onto your motherboard which is much expensive to get fixed.
Hope this helps.
