You will need to reformat the hard drive to the factory condition. After is says its corrupt it should give you the option to do so. If it will not format, then the hard drive has probably failed and a new one will be required. I have purchased several off of ebay and had the systems back up and running.
1. Start with having the system in standby (redlight is on) 2. Hold the power button down; the system will turn on and turn off once again. 3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try) 4. You will be prompted to plug in your controller via USB and then hit the PS button You will now have a screen with these options (I have attached a picture of this screen below) 1. Restart System: Restarts the PLAYSTATION®3 System. 2. Restore Default Settings: Reset all system settings back to default. CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files. 4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3. 5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch. 6. System Update: Update the PLAYSTATION®3 System IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM I REPEAT CHOOSE RESTORE FILE SYSTEM After this, it is going to restart and bring up a screen reading something like "you have Corrupted System Data. Your PS will now replace this data" Then you choose continue and that should be it. This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that's stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system. If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive. However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren't corrupted) back to the flash memory which is corrupted thus fixing the problem
The current version of the ps3 firmware has a “recovery console”. You access it by
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
Here is a video of the recovery screen. www.youtube.com/watch?v=m0SPmkV-jco If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive. However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash memory which is corrupted thus fixing the problem.
If you are gettting the corrupted drive message this means that you have corrupted data on your hard drive. The link below will help you address this. If you still have trouble then most likely you will need to replace the hard drive.
You most likely need to replace your HDD. How to do it links below.
www.gamespot.com/features/.../index.html - vgstrategies.about.com/.../ps3cheatsandcodes/.../PS3HDDUpgrade_7.htm kotaku.com/.../upgrade-your-ps3-hard-drive-step-by-step
Be sure to folleow these instructions to the letter, you could damage your PS3 if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive isoption 3: RESTORE FILE SYSTEM
Here is a video of the recovery screen. www.youtube.com/watch?v=m0SPmkV-jco If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive. However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash memory, which is corrupt, thus solving the problem.
Ok, it appears that your hard drive in your PS3 is corrupt and needs to be reformatted. You can get an external hard drive enclosure and do it yourself. You would have to take the hard drive out of your PS3 and put it in the external hard drive enclosure and plug that into a computer with the supplied USB cable and format it. From what I'm reading out there, the external hard drive enclosure has to be for SATA 2.5" hard drive. You could probably replace the hard drive with a larger one just as easy if you wanted to. If you don't feel comfortable with any of this, then its probably repair shop time. I hope this helps.moreover,,Use your recovery disc to reinstall your operating system. This should clean up your hard drive and restore any missing or corrupt files.
