SOURCE: Can't find AOSS Button in psp
you are doing it in the wrong menu. you are setting up a connection to location free player
you need a wireless connection. And so after that, you go to the internet icon,and then you just type in your link.
1. Go to the Main Menu of your PSP.
2. Go to Settings.
3. Scroll down to Network Settings and Press the X button.
4. Select Infrastructure Mode.
5. Select New Connection.
6. Name the connection so that you know it is for web browsing. (ex. WebConnect)
That way you can use another connection for the rest of your online games.
7. Push the Right Direction Key to go to the next menu.
8. Select the Scan option and let it pick up your WLAN settings.
9. Once it picks up a connect, Push the Right Direction Key to go to the next menu.
10. Select Custom for the Address Settings.
11. Push the Right Direction Key to go to the next menu.
12. Leave IP Address Setting on Automatic.
13. Push the Right Direction Key to go to the next menu.
14. Select Manual for your DNS Setting.
15. Push the Right Direction Key to go to the next menu.
16. Enter in 67.171.70.72 as your Primary DNS and just leave the Secondary DNS blank.
17. Push the Right Direction Key to go to the next menu.
18. Select "Do Not Use" for your Proxy Server settings.
19. Push the Right Direction Key to go to the next menu.
20. Push the Right Direction Key to go to the next menu.
21. Push the X button to save your settings.
22. Do a quick test of the connection to make sure it's working correctly.
first
you need to have a wireless internet at home. next you need to turn on
the wlan on your psp, located at the left side corner of your psp.
search for a wlan around you. if its not secured, your lucky, you can
connect anytime, but if it has a wep key, you need to find out the key
to be able to connect.
Switch the
wlan button (located on the left side) to on and if don't aoss router
seperate from the psp you cannot use automatic. So goto new connection
and press scan. Follow on screen instructions.
If you do have an aoss router press button on the aoss router inself so the psp can find it.
Okay now that ive given you your answer make sure to follow fixya's system. Instead of taking the answer and running.
THANK YOU,
NATE
SOURCE: WHERE IS THE AOSS BUTTON O A PSP
No, there is no AOSS Button on the PSP. You have to have a router. This router is hooked up to your computer and is around a $100.00 but you have to have DSL or something like it to run a phone line though. If you do not have this you can go to a Holiday Inn or Wal-mart parking lot who has this router hooked up already. You can access to the internet there.
SOURCE: i cant find the aoss button on my psp
That's because there isn't one.
HERE is a good guide that should have your PSP on-line in no time.
please rate my solution.
