I need to scan a Deed which can't be pulled apart so I have to use the flatbed on a Aficio 2045 model. How can I scan all of this document - say 50 or so pages as 1 document please?
Ricoh Aficio 2045 copier/printers take the Ricoh Type 3110D Toner Cartridge. Go with OEM toner on these machines. The generic version tends to make them run dirty.
the aficio 2045 is new version of the aficio 450. so on the 2045 if you have installed printer/scanner option you can scan directly to folder on your computer or you can scan and sent documents to email addresses ,also the print or copy is much more quality. you have a touch screen control panel. mainly the look is the same with some new design on the look, but also some staff which has bean detected as problem on the aficio 350 now are corrected and improved.
ola ha a possibilidade de voce desmontar a LD INIT e limpar o LED do laser e os espelhos que ficam dentro do laser. e um pouco trabalhoso mas da certo pois o toner derrama dentro do laser e ele nao consegue mais sincronizar. precisa retirar 6 soldas das tres pernas dos 2 leds e retirar os parafusos.
Try scanning using Scanwizard instead of using directly in Photoshop. If it freezes again, it might be some problem with your system since there's no indication of hardware conflict. Additional info like Microtek scanner model name and current Windows version. Normally, Adobe wont have any problem regardless the scanner model, as long the appropriate driver installed.
Loading originals to scan Use these instructions to load originals into your device for scanning. For the best quality scans, use the flatbed scanner. See Selecting media for the automatic document feeder (ADF) for guidelines on choosing original documents for scanning. Loading originals onto the flatbed scanner 1. Make sure that the automatic document feeder (ADF) input tray is free of media. 2. Lift the flatbed scanner lid. 3. Place the original document face-down on the flatbed scanner with the top, left corner of the document at the lower-right corner of the glass. 4. Gently close the lid. 5. The document is ready to be scanned. CAUTION To prevent damaging the device, do not allow the scanner lid to fall onto the flatbed scanner surface. Always close the scanner lid when the device is not in use. Loading originals into the automatic document feeder (ADF) input tray Note The ADF capacity is up to 50 sheets of 75 g/m2 (20 lb) media (depending on the thickness of the media), or fewer sheets if the stack fills the ADF. The minimum size for media in the ADF is 127 by 127 mm (5 by 5 inches). For smaller sizes use the flatbed scanner. The maximum size for media in the ADF is 215.9 by 381 mm (8.5 by 15 inches). 1. Make sure that the flatbed scanner contains no media. 2. Close the flatbed scanner cover and put the top end of the stack of originals into the ADF input tray, with the media stack face-up and the first page to be scanned on top of the stack. 3. Slide the stack into the ADF input tray until it does not move any farther. If this helps you, let the Boss, FixYa.com Know...
