F20 = NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED.
The pressure switch is not tripped after 6 minutes.
If there is no water in the unit:
Make sure that both valves at the water source(s) are turned on all the way.
Check for plugged or kinked inlet hoses or plugged screens in the inlet
valves.
Verify inlet valve operation.
If there is water in the unit:
Verify drain pump operation.
Verify that the pressure switch hose is in good condition and properly
connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Press PAUSE/CANCEL twice to clear the display. The machine will drain
for 3 minutes before unlocking the door.
3. Unplug washer or disconnect power.
4. Verify wire harness connections to inlet valves, pressure switch,
drain pump and Central Control Unit (CCU).
5. Check all hoses for possible leaks.
6. Plug in washer or reconnect power
7. Verify pressure switch operation.
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Hi - F20 on this model is indicative of a clog in the discharge area of the unit. Pump failure or discharge clog. Are you use to using tools? Generally this is an easy repair if you are.
