I had a bad jam but it's been cleared. Now, however, the display says "Fuser Error. Low Temperature" Help!
There is a small thermometer that contacts/sits very close to the metal heat roller on your fuser, chances are when removing the jam its been bent away from the roller, have a look and try and see if you can see it, not knowing this exact printer im not sure the exact position but it is usually in the middle of the roller coming from the top of the fuser housing, another thing to check is if your fuser is actually warming up atall, if you cant feel any heat then the fuser lamp that heats it up has gone bad
