Televison & Video Logo
Posted on Nov 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
60 inch sony tv overheating. can an outlet make your tv overheat. had some recessed lighting put in ceiling and tv has been cutting off after 1 hour of play ever since. could the room be too hot. could the outlet be generating too much heat
Eric Rotmil
Level 3:
  • Master 587 Answers
  • Posted on Nov 14, 2009
Eric Rotmil
Master
Level 3:
Answers
587
Questions
0
Helped
175543
Points
1898
Hi my name is Roety,
I can help you with your issue ,
No I doubt its from normal room heat, could be the heatsink compound is dried up on the ICs
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
2answers
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
My sony 60 inch tv plays green is there lenzes in the optical block that crack
You have a defective Light Engine/optical Block.
Call this number and see if Sony will pay to have it Fixed They were extenting warranty on these Models due to so many Light Engines going Bad.
PTS rebuilts light Engines 1-800-844-7871
UED 1-800-648-6657
Encompass Parts Distribution 1-800-638-3328
I hope this will help you.
My sony 52" keeps cutting
You may have bad power and your TV may be reacting to voltage drops or spikes. Is your TV powered through any kind of conditioner, surge supressor or filter? If not, you should consider getting one even if its only a $100 item. Stay away from standard or computer power strips though. Make sure it is not overheating and you have plenty of cooling space around the TV both to the sides and back, if it starts to overheat it will shut down. Or it could be a panel or internal board error. You'll need to get Sony tech to diagnose the problem. Are you getting any blinking lights when it shuts down? these are a code for the techs to let them know what to start looking at .
1helpful
I have a 60" Sony
is the lamp light flashing? if yes, lamp needs replacement. you can buy lamp from www.sony.com/dapc
if lamp light if not flashing, turn off tv for 5 mins. then unplug for 1 min. if the same. tv needs service. check www.eservice.sony.com
9helpful
3answers
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Am I allowed to cut wire then reconnect using a junction box???
As long as you wire it correctly, should be no problem
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
TV is going on/off
had same problem with sony 42" when i was using it with a sky digital decoder it turned out to be the scart output on the decoder try change the scart to a different outlet there should be a second one on decoder.
this problem can also accure if the tv is overheating
2answers
Tv cuts off and green light flashes
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
