Sony KV-29LS60 29" TV Logo
Posted on Jan 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV goes into standby and Powerled blinks 2 times
my Sony TV goes into standby mode and the leds blinks 2 times. I've found out that it has to do with OCP, but can I do something about it myself (maybe clean the TV?) or is it better to let it repair by a professional.
Thanx in advance.
Greetingz Frank
  • looneyhill Jan 06, 2008
    Thanx for your fast response! Best wishes for 2008...
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 07, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
413
Points
I need for my tv sony a antena conector k29kf1 can you solve this
Anonymous
Level 2:
  • Expert 97 Answers
  • Posted on Jan 06, 2008
Anonymous
Expert
Level 2:
Answers
97
Questions
13
Helped
46651
Points
224
Get checked by professional. also heck the manual, local shops should be able to find a solution
Red light blinks 3 times
I found this with a google search. I will put the link here to give credit to the site. This is not my own info. Full credit goes to the site owner.
  • 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Two times red led blink error
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Sony Trinitron clicks 5 times then standby light blinks 2 times every few seconds
It is due to over voltage form the SMPS power supply to horizontal output section circuit. If this voltage goes higher than normal, the set will shut down, showing two blinks of standby lights. I've recently found one site that details all these matters well. "electro-help' is the site name. Google for it. have all details, and I'm sure that you will get all details.
2helpful
Sony kv36xbr800 won't turn on -standby blinks 2 times pls help
Tv sony stop after 20 min standby led flashes 3 times
HI,
By three blink it means the B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is because there is problem in the power supply circuit. Check for any dry soldering in the power supply side. If the tv is working properly for 20 minutes then its sure that there is some dry soldering joints in the power supply side. You have to resolder suspected soldering contacts using soldering ion and solder. The dry soldering joints will look like on in the picture.
ajin_g_109.jpg ok
The TV keeps going into standby mode , comes back to proper picture and with-in 15-20 seconds goes back into standby mode. It happens continueously.
May I know if the standby led light at the front panel is blinking, if so please count how many times it will flash to determine the error code? If not follow the steps below.
In standby mode press the button of the remote control in sequence, " Display ", " Channel 5 ", " Vol (-) ", " Power ". Self diagnosis screen will displays. Le me know the result.
Jdvillanueva
1helpful
I have sony 29'' crt tv . model no KV-DZM61 .when the tv statrs on it shows green led,and after few second the led glows red and it blinked for 2 times .then the tv goes in stand by mode
2 blinks means - over current protection (OCP) , unit goes to the standby
16helpful
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
1helpful
Sony KV30hs420 0 Stanby Light Timer Blinks 3 times and powers TV off
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. If you have electronic knowledge you may be able to fix it. Let me know if I could help you further.
Hope this helps.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
