20 Most Recent Toshiba CN36X81 TV Questions & Answers
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. If you have electronic knowledge you may be able to fix it. Let me know if I could help you further.
Hope this helps.
Toshiba CN36X81... | Answered on Jun 10, 2019
my tv, when turned on via remote or manually pressing the power button on tv does not turn on. The TV power light powers on red but makes a clicking sound as if if were turning itself off after power up. (clicks on then clicks off) Humm? What could the problem be? Is there a repair part that is needed? If so. what might that be and is there a schematic or some sort of diagram to show how this issue can be resolved?
Toshiba CN36X81... | Answered on Sep 02, 2010
IF coming in via, the "Dish" networked receiver, please check that this volume is turned way up, on the TV. and then control the the Volume, with the Dish Remote, often this is a problem, as one is turned down, and the other cannot turn that up, simply try syncing the Volume controls, UP on TV, control the Audio with dish remote. thats all i can think of. Check by feeding a signal IN from an AV, source, ie: Yellow, Video, & Red& White, Audio. Turn TV UP and check, IF it responds to this all is well. If NOT then you do indeed have a fault, with the TV.
Toshiba CN36X81... | Answered on Mar 27, 2010
You have a frame collapse problem. Line, EHT, power supply, video and sound stages are all functioning. Check frame output ic for dry joints, resolder all pins. HT supply for output ic's derived from line stage check for open circuit safety resistors around line output transformer, if you find any then frame output ic will also be suspect. WARNING Very high voltages exist around the line stage. Make cold tests with Ohm meter with set unpluged from mains supply.
Toshiba CN36X81... | Answered on Feb 27, 2010
check the circuit board, resolder all the Ic pins specially in IC jungle area.
Toshiba CN36X81... | Answered on Aug 07, 2009
I would try a power drain:  Unplug the TV's power cable so the TV is not grounded to the house.  Then press and hold in the TV's own power button for one minute to drain the capacitors. Plug the TV back in and see what happens.  If the TV will still not turn on, I would say you have a problem with the TV's mainboard as a dead power supply will not light any LED's for you.
Toshiba CN36X81... | Answered on Mar 24, 2009
Hi: Your set has a power or high voltage circuit problem. Depending on parts cost it may or may not be expensive to repair. Get an estimate from a reliable repair tech. Good Luck.
Al
Toshiba CN36X81... | Answered on Mar 13, 2008
Hope this helps.
Toshiba CN36X81... | Answered on Jan 25, 2008
go into audio settings see if speakers on if ok try input or source change some have pic no sound
Toshiba... | Answered on Sep 15, 2019
Try https://www.manualslib.com/products/Toshiba-49l310u-4149107.html
Toshiba... | Answered on Sep 13, 2019
LOL I would say toss or bin it .14 years is a good life time in electronics
Toshiba... | Answered on Sep 07, 2019
Backlight inverter board fault.
Contact any service center to get it repaired, or replaced.
This type of fault can't be rectified by a normal user. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Toshiba... | Answered on Sep 06, 2019
Toshiba CN36X81 TV Logo
11 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
power problems problem
  • Televison & Video
