my sony kdf-55wf655 has blue haze in bottom left coner on bottom 6to7 blue small dots in middle of...
(More)
my sony kdf-55wf655 has blue haze in bottom left coner on bottom 6to7 blue small dots in middle of screen dots noticeable on dark or black sceens
Sony LCD rear projection model KDF-55WF655. Cross-hatch discoloration pattern on right side of...
(More)
Sony LCD rear projection model KDF-55WF655. Cross-hatch discoloration pattern on right side of screen appx 16 inches long and 4 inches wide. Diagnosed as optical engine failure? Any reason I can not install the new engine myself??? I am extremely mechanically inclined.
The power led flashes 3 times green and the 6 times red and then continues to repeat the patttern....
(More)
The power led flashes 3 times green and the 6 times red and then continues to repeat the patttern. nothing else happens
it is not the bulb/lamp led...and i changed the lamp just for giggles($189 wasted)
sony-kdf-e55a20 rear projection 1-1/2 years old
any suggestions...
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
written by Ecollier2012
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound Fan error 4 times - Fan1-4 Power is not supplied.(G2 board) - Fan...
written by SUPERMAN_B_1
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
