20 Most Recent Sony KV-27FV16 TV Questions & Answers
It is due to over voltage form the SMPS power supply to horizontal output section circuit. If this voltage goes higher than normal, the set will shut down, showing two blinks of standby lights. I've recently found one site that details all these matters well. "electro-help' is the site name. Google for it. have all details, and I'm sure that you will get all details.
Sony KV-27FV16... | Answered on Jun 14, 2012
check all voltage output from secondary ouput of SMPS, specially the B+ going to flyback transformer if open and also h-out transformer oscillator voltage. please call a qualified personnel if your not electronic expert. to avoid of electric shock.
Sony KV-27FV16... | Answered on Aug 15, 2009
If the lights don't come on the tv ,try to connect the tv to the other power point
and check if it powers on, if its does not power on then its the problem with
fuse inside the tv replace the fuse and check its works ...and also test the power chord for continuity ..
Good luck...
Sony KV-27FV16... | Answered on Feb 18, 2009
The picture tube on your tv is dead, you need to replace it. It probably will be worthing just purchasing a new set, because the cost of repairing it will be close to the purchase of a new one.
Sony KV-27FV16... | Answered on Feb 09, 2009
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
Sony KV-27FV16... | Answered on Jan 13, 2009
rf converter connector can be replaced 50 100 est
Sony KV-27FV16... | Answered on Dec 02, 2008
Try going into the audio settings part in your menu and select reset audio settings.
Sony KV-27FV16... | Answered on May 17, 2008
Go into the video settings section on the tv by pressing menu and reset the video settings.
Sony KV-27FV16... | Answered on May 16, 2008
We had this problem, we took it back and they said something about the tubes in it, they had to give us a new one.
Sony KV-27FV16... | Answered on Jan 20, 2008
This is the most common death mode for TV's. The high voltage is acting up. You set is not quite 10 years old right? Can be fixed, but involves replacing the Flyback transformer which is not cheap. It is a toss-up as to whether it is worth putting the $200 or so it will cost to fix into a set that has limited expected lifetime.
Sony KV-27FV16... | Answered on Dec 31, 2007
I'm not sure if you solved your technical issue or not, but if your TV is still broken, I would be interested in buying the door that covers the AV inputs. This door is on the front of the TV. Unfortunately, mine broke, and it's been difficult to find a replacement. If you are interested, I can be reached at (612) 801-5752 or by email at tremely@mac.com. Thanks.
Sony KV-27FV16... | Answered on Dec 09, 2007
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Sony KV-27FV16... | Answered on Nov 23, 2007
once you have diagnosed the problem, the following link is to all parts for your tv stocked at partstore. they generally have better prices than the dealers and repair shops.
KV-36fs13 parts
you can try the dead-tv kit from fixyourowntv if you have some basic experience with soldering and circuit repair.
http://fixyourowntv.com/orderpage.php
Five blinks means, "IK (AKB)" (white balance). The probable causes listed by Sony are as follows:
1) Video OUT (IC561) is faulty (A board)
2) IC355 is faulty (A board)
3) Screen (G2) is improperly adjusted.
not sure what the 13 blinks are for.
hope this helps,
trin
Sony KV-27FV16... | Answered on Nov 19, 2007
You may have a bad solder joint on the horizontal driver transformer or somewhere else in the set. I found this problem with this transformer several times. Stargazer
Sony KV-27FV16... | Answered on Apr 10, 2007
The set may have shorted the horizontal out put transistor since it kept coming on sometimes. This could be cause by the driver transformer arcing causing a "spike" in voltage going to you horizoltal out put transistor. Stargazer
Sony KV-27FV16 TV Logo
26 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
necesito diagrama tv sony kv 27fv16
  • Televison & Video
