20 Most Recent Sony KV-29LS60 29" TV Questions & Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sony KV-29LS60... | Answered on Nov 08, 2015
First check the menu to see if the internal speakers are enabled(if you have this option). If that does not solve this, then there is a module inside the set that has gone defective...It was a common problem on these sets and will require a serviceman to repair as it needs to be unsoldered andthen resoldered in. The module is part of the stereo decoder and is usually not repairable as there are many surface mount components on it. Besides, it is cheap enough to get new one to replace than to try to fix it.
Sony KV-29LS60... | Answered on Dec 19, 2010
IN THIS SONY TV KV- XJ29M80, IM FACING A PROBLEM THAT SET GOES TO ERROR MODE WITHIN FEW SEC'S AFTER GETTING IT ON, AND THE LED INDICATES 2 BLINKS AND GAP AND AGAIN 2 BLINKS AND CONTINUES..PLZ HELP ME ...I WAS FOUND THE HORIZONTAL OUTPUT TRANSISTOR BLOWN AND THE 1.2 OHM RESISTANCE ALSO FOUND BLOWN...I REPLACED THE BOTH BUT THE PROBLEM IS CONTINUE...
Sony KV-29LS60... | Answered on Oct 20, 2010
Check T603,and R672,check all connections,swollen or leaking capacitors,burent resistors,fuse.hope this helps you some.
Sony KV-29LS60... | Answered on Mar 01, 2010
get checked by professional. also heck the manual, local shops should be able to find a solution
Sony KV-29LS60... | Answered on Dec 07, 2009
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Sony KV-29LS60... | Answered on May 22, 2009
it is power supply problem. your oscillator for switching ckt or switching output failure. if you are not tech person call him for help. it is not a major problem good luck.
Sony KV-29LS60... | Answered on Jan 20, 2009
Hi Bruce, if you want to directly control your Sony KDL-37L5000 TV with your Sony RM-YD028 remote control, it should work without any problems, at most you will have to reconfigure it with the Sony TV code
I hope you can resolve your concern
Greetings Franco Dosil
Sony Televison &... | Answered 3 days ago
Sony KV-29LS60 29" TV Logo
19 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony tv kv xj29m80 need know error code
  • Televison & Video
