Go to the hp website
www.hp.com on the dv4000 computer. Enter dv4000 and then the sub model number on the label from the bottom of the laptop. Then allow the installation of the driver scanner from HP to download/install (press OK to continue to install and let it scan the unit for needed driver updates), then go to the Audio section of the then listed drivers. after entering the operating system installed (see Start>Control Panel>System>General tab for installed OS info), and install that latest Audio driver package update. I would also personally install all the other required driver(s) & the latest BIOS update listed there also myself. IMPORTANT: When installing the latest released (or highest #'d) BIOS update (the BIOS simply allows all the hardware to work together w/ the OS), make sure the computer is plugged in, and do not interrupt the install process or restart/shut down the unit until the program does it for you. (If you have never "flashed a BIOS" before...Have a techie friend do it for you instead, after downloading the proper file/& flash utility...Real patience pays here, or you can flat turn a motherboard into a useless doorstop). It can always be reflashed by the manufacturer (or others), though even if a BIOS Flash is messed up.
Free Belarc Advisor (
www.belarc.com) if installed and run will inventory all your hardware & software if you have any questions about whether a specific driver listed matches your specific hardware concerning that dv4000.
There were a few HP dv series laptop motherboards that had a problem holding both Video & Audio drivers (install 1 and the other would blow out & get corrupted), install the other and just the opposite...They had a class action settlement that was only 90 days or 6 months long and really screwed many of us over in the process. If there is a choice between the dv4, dv6, & dv7 series I always pick the dv7 series to recommend to & for my customers.
I flashed my laptop with wrong BIOS (version f.17 )
Now the laptop is not even Booting up.
I tried the following.LEDs are ON
Unplugged it from Mains
Removed the battery
Pressed the power button for about 30 seconds
Plug the laptop to Mains
The LEDs came up.
Then i tried the Crisis Recovery Disk Option (i.e. copy the correct bios in a floppy drived, used an USB Floppy Drive and try to boot with Win + B option. - Nothing happens.No display (even to external monitor)
Help Me..
Is there anyone who can reflash it with the correct BIOS for a nominal fee?
I was given a dv4000 that was not working. I have the exact same issue. I start it u and no dislay on the LCD or an External Monitor. I've removed the battery/power cord and pressed on the power button for 30 seconds. On boot up after that it does the same thing. No display. No way to get into the bios nothing.
While I power up with or without the cord I do not hear the HD spin nor does the fan.
I was thinking this could be a graphics card or motherborad itself having issues.
Any further help would be GREAT!
So How to Solved Your Problem Please tell me because Same Problem in my Notebook So i will be Repaired It
