Sony Playstation 3 (PS3) Console Logo
Posted on Jan 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HDTV no video or audio
Was connecting my ps3 to my HDTV and set the video output to 1080p and the screen went blue. ive found out that my TV doesnt support 1080p. tried the pressing down of the standby button but it doesnt work.my operating system is 2.1.please help!
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
239
Points
PS3 is The amazing device by sony but it has some common problems like sound , video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Jose Ramirez
Level 2:
Sergeant:
  • Expert 264 Answers
  • Posted on Jan 06, 2008
Jose Ramirez
Expert
Level 2:
Sergeant:
Answers
264
Questions
0
Helped
100531
Points
555
Http://www.us.playstation.com/Support/PS3/GettingStarted/default.html get on this page and follow it for trobleshootings fixya rate
I am getting a blue screen whenever i turn on my ps3. Ive tried resetting the system several times and can not find the solution. Audio works just a blue screen on the t.v.
You said the sound works but you get a blue screen on the TV, check your TV if it is set properly.
Make sure the Input is correct on the TV to shoe the Video coming from the console and check if the cable connections are properly connected to the TV and the console video output and input.
Also try it on a different TV to see if the issues is with the TV or the Console itself if on a different TV and the issue is still the same the issue is the Video output from the console but to check further more try a different cable, borrow one or maybe buy a new one just to see and eliminate possible causes of the Blue screen issue.
I hope this helps.
2helpful
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
2helpful
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
1helpful
Hooking up ps3
To get 1080i (the 50V will not do 1080P) from the Blu ray player you do have to use HDMI output on the PS3 to the DVI input.
I found one at Walmart. Phillips makes an HDMI to DVI plug also at Wmart.
The PS3 must be set for the output you want on your TV.
Look in your manual in the PS3 box or go to http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
The web site has much more detailed instructions, but the basic answer to your question is below.
  • The cable required to output a particular video mode may not be included with the product and additional purchases may be necessary. For details, refer to the documentation supplied with your system.
  • If the video output settings do not match those required for the TV in use, the screen may go blank when the resolution is changed. The screen should, however, automatically go back to its original resolution after a while. If the screen remains blank for more than 30 seconds, turn off the system. Then touch the power button on the system front for at least five seconds to turn the system on again. The video output settings will automatically be reset to the standard resolution.
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
  • Copyright-protected Blu-ray video discs can only output at 1080p using an HDMI cable connected to a device that is compatible with the HDCP standard.
  • Hope that helps!
    Merry Christmas and Happy Holidays to you and your family.
    2answers
    I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
    1. Check the resolution supported by your TV.
    2. Select (Display Settings) under (Settings) in the home menu.
    3. Select [Video Output Settings].
    4. Select the connector type on your TV.
    D2: 480p / 480i
    D1: 480i
    5. Change video output settings.
    6. Set the resolution.
    7. Set the TV type.
    8. Check your settings.
    Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
    9. Save your settings.
    The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
    PS3 does not work in 1080p
    My ps3 didn't like a HDMI connection very much. I tried the Composite input cables and they worked great with no screen flicker.
    -Captain Jake
    1helpful
    Cant get hdmi for ps3 to work on my jvc hd 52g887
    Had same problem with Panasonic PT60LC14 tv when connecting by HDMI cord to my PS3 and a blue ray disc was playing. First, read your tv manual to see what video inputs it supports . Then read the PS3 online manual (section on "video output settings").
    For me I found out that my tv only supported 1080i (along with 480i/p, 780p) and the ps3 manual says blue ray outputs 1080p, so my blue ray discs will not play on my tv according to the PS3 manual. PS3 manual says to restart the ps3 (power off, then power on and HOLD for 5 seconds) - then the standard video output settings should be reset. Hopefully the ps3 menu will pop up at least. I haven't tried this yet but if it doesn't work, i'll may try to reset PS3 video out settings manually first using another tv that works with it ..
    Problem connecting HDMI cable
    Hey there I don't see why your playstation 3 should be doing that other than the console being defective. Sony doesn't have this problem that often and actually this is the first time i have heard of such problem. Try making sure the the HDMI cable is connected at both ends all the way in and also make sure your Samsung is a 1080P which i am pretty sure it is and finally if you have a friend or another 1080P HDTV in your house i would try and see if your ps3 will support the 1080P feature. If you still have the problem even when you use a different TV then its the ps3 that is malfunctioning otherwise it would be your Samsung. Let me know how that turns out alright.
    77helpful
    21answers
    Playstation 3 Flickers when set to 1080P
    It sucks to see ALLLLLLL these solutions, when I have the solution. Turn off DEEP COLOR in the video settings. It will immediately stop. If it doesn't, then you don't have the typical snow/flickering problem.
    2helpful
    Toshiba 32AV500U HDMI issues
    The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
    Top Sony Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Jose Ramirez
    Alexander
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
