Hitachi 51SWX20B 51" Rear Projection Television Logo
Posted on Oct 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When trying to run magic focus on Hitachi 51swx20b, it stops on green. Picture is curved on the bottom of the screen
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 16, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
352
Points
Have an Hitachi 51swx20b. The colors are not aligned and magic focus will not work. Vertical and sharpness is grayed out...
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 277 Answers
  • Posted on Oct 31, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
277
Questions
0
Helped
53512
Points
818
You can adjust the curf on the main menu under sceen ratios
Shaded color tinting everything in pink and green. I've tried Magic Focus (5). It's a Hitachi 51SWX20B.
sound like a common problem where the coolant for the tubes has become contaminated. It is possible to replace the coolant yourself and can be a much cheaper alternative to getting repair shop to fix.
do a search for replace coolant 51swx20b
My Model TV # is 51swx20B. Two days ago the picture started having a lot of green in it and no blue. What is the repair needed.
Do adjustments on focus block. Will have to open front panel access door, focus block blue will be on left, green will be on top. Top screen bottom focus. Turn clockwise to increase, counter clockwise to decrease brightness. Turn the color all the way down on menu where it's pure black and white and make adjustments for perfect black and white picture, then when you adjust color, it will be perfect.
1helpful
Hitachi 51-SWX20B Out of focus...tried magic focus and it stops on red. Tried manual focus but red lines won't move. How expensive is this going to be to fix. It is 7 years old and need to know if I...
YOU HAVE A CONVERGENCE PROBLEM. THE RED OUTPUT IS OUT. COMMONLY IT HAS BEEN FOUND TO BE THE DIGITAL CONTROLLER MODULE THET CAUSES THIS BUT THE OUTPUT IC SHOULD BE CHECKED FIRST
Magic focus error Hitachi 52
The model number you have selected here does not have magic focus--if you really want a answer post the correct model number.
SD TECH
Green is way out of alignment
Need to have convergence board rebuilt, do not adjust anything this will make the technician charge more for the additional labor of having to "undo" your "repair" leave it for a professional technician, as it can be dangerous. we would charge at least $400 this would include readjustment. Millenium Tv - [email protected]
1helpful
Will not show red color in picture, magic focus shows red though
You have a projection light element out. I had the green element go on mine. I had a service agreement so a repair tech changed it.
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
7helpful
2answers
Hitachi 51SWX20B Convergence problem
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Loss of color picture
I have a blue-ish yellow ghost tint which just appeared on my 51" 51SWX20B made July 2002. Did the magic focus got a number 5 at the end. Did you get a number when you did the magic focus?
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
