There are a couple hundred thin, colored vertical lines on my olevia lcd tv. What's wrong? The...
(More)
There are a couple hundred thin, colored vertical lines on my olevia lcd tv. What's wrong? The picture is still there. It happens when playing DVD's and when watching cable. I tried turning the tv off, unplugging it, and then turning it back on. It didn't help.
I have a Hitachi UltraVision model# 50UX26B that has started to show a RED shadow on the screeen. I...
(More)
I have a Hitachi UltraVision model# 50UX26B that has started to show a RED shadow on the screeen. I tried to use the 3 different Magic Focus funtions and it does not make the RED shadow align up. Any help you can give will be very helpful, and if you need more info please let me know.
How does a hitachi 51" rear projection tv 51swx20b come apart to get it out of the basement? I...
(More)
How does a hitachi 51" rear projection tv 51swx20b come apart to get it out of the basement? I had to remove a door frame, and had two giants pop it through to get it in several years ago. Replacing tv, and giants not available, and don't want to remove door frame. Would prefer not to damage tv, but willing to risk it to make it easier to remove.
replaced conv. chips stk150. It turns on now but red overshadows other colors and focus magic...
(More)
replaced conv. chips stk150. It turns on now but red overshadows other colors and focus magic doesn't work
I have a 51SWX20B that will turn on but has no picture, volume, or menu screen. It doesn't seem to...
(More)
I have a 51SWX20B that will turn on but has no picture, volume, or menu screen. It doesn't seem to be a power problem, just a video problem.
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Before you order new convergence chips to try to fix the double vision or 3D look on your tv check the solder points for the chips. If you are able...
written by misenhei
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
