I have a Hitachi Ultravision HDTV model number SP-43w. When you turn it on it is red and wavy across...
(More)
I have a Hitachi Ultravision HDTV model number SP-43w. When you turn it on it is red and wavy across the top and the picure is distorted. It was purchasd in 2002. What is wrong with it and how much would it cost to get fixed?
power comes on but no picture or sound. Just bought the tv used. Hitachi. Wondering if it is just...
(More)
power comes on but no picture or sound. Just bought the tv used. Hitachi. Wondering if it is just something that needs done after you bring tv home.
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Before you order new convergence chips to try to fix the double vision or 3D look on your tv check the solder points for the chips. If you are able...
written by misenhei
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
