How do I reassemble a Kenmore model 110.29842991 agitator
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.29842991
See the Agitator and Tub section.
Basically lower the main agitator onto the transmission drive shaft. (Be sure that the two pronged "washer" and clip are on the shaft).
2. Screw the double threaded bolt (with a rubber washer on the bottom) into the agitator shaft
3. Carefully lower the top agitator onto the lower one and screw the 1/2" (probably plastic) bolt onto the double threaded bolt.
4. Put the cap on
5. Put the fabric softener unit on and push down on the locking ring.
Item #2744
(OEM Part)
$19.85
Washing machine agitator
repair kit with a medium length cam (there are other kits available for
different models). This kit should be used when the top part of the
agitator is not moving properly but the bottom part is.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/285811/2744?modelNumber=110.24722300
