Re: Have red tint on the screen gives off a double image.
The PT53WX53 Convergence repair kit available at www.tvrepairworld.com should repair that issue. The kit contains the parts and the CD with instructions
If this is a VO47LFHDTV20A TV set, the problem is most likely your LVDS(cable from the main board to the t-con)cable is faulty. When you turn the set on, do you have a red screen instead of the standard blue screen? Do you also have red tints on all images on all inputs? If this is the case, your LVDS cable is bad. If you are comfortable opening up your set, track down where the LVDS cable goes into the t-con board. Turn on the set, and wiggle the cable, if the red tinting goes away, you will need a LVDS cable, about $24 part.
IT SOUNDS LIKE A PINCUSHION PROBLEM. IN MOST CASES IT IS DUE TO CAPACITORS GOING BAD ON THE BOARD. OTHER TIMES SOME TV'S HAVE LARGE MICROCHIPS THAT RUN THE PINCUSHION AND COLOR SYNC. HOPE THAT HELPS.
The convergence circuit has failed. It is not a easy fix due to the tear down needed to get to the circuit area. I would call Mitsubishi at 18003322119 to get a Authorized Service Facility to check it out and give you a estimate of repair cost.
The liquid coolant between the guns and the lenses may be fogged, low, or both. If the red gun has fogged coolant, you'll see red fringing around objects. It can be drained and refilled with new coolant, but it's gotta be the right stuff. You may be able to get some from a junk set, as I have done with success. Shine a light into the front of each lens. If the liquid has gone bad, you'll be able to see it.
Need to replace the two STK392-110 Covergence ICs. You can get replacements at the following link with free instalation instructions http://servicemanuals.vstore.ca/
Hi you have bad convergence ic stk modules ,Cost for repair center to fix is 250.00. call your local repair center ask there prices on convergence ic repair. It is a very common problem every 3 to 5 years .Our service center does a lot of these.
sounds like image burn,try it on normal viewing size and see if its still there and in the same area if so image burn on crt from the 4:3 aspect mode .
