Question about RCA HD52W56 52" Rear Projection HDTV
Double images on screen
Double images and the color is off- has a blue tint to eveything. As a message scrolls across the bottom of screen from right to left the double images are more pronounced in the middle of the TV. Help.
Posted by bhk9 on
JEFF
    New Friend:
  • 60 Answers
IT SOUNDS LIKE A PINCUSHION PROBLEM. IN MOST CASES IT IS DUE TO CAPACITORS GOING BAD ON THE BOARD. OTHER TIMES SOME TV'S HAVE LARGE MICROCHIPS THAT RUN THE PINCUSHION AND COLOR SYNC. HOPE THAT HELPS.
Posted on Feb 20, 2010
Blue Double Image
try another TV,if it is the same situation,the problem is with cables or GPU,if not ,your TV is maybe not compatible,than try with smaller resolution
Mar 07, 2014 | Toshiba Satellite Computers & Internet
On my Toshiba Tecra when in GoogleChrome the the image on the screen is 25mm too far to the right. This makes it impossible to use the up/down key at the top right of the screen and the enlarge and...
Have you tried double clicking on the bar right at the top of the screen next to the minimize, maximise, close buttons? By double clicking in this area it'll change the size/shape of the browser screen, you can then reposition the window to the top left of your screen and then click and drag the bottom right hand side of his window once the cursor turns into a double headed arrow.
Apr 18, 2011 | Computers & Internet
Blue tint across screen and black shadow of sort
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 02, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Colors bleeding, red tint around images
The liquid coolant between the guns and the lenses may be fogged, low, or both. If the red gun has fogged coolant, you'll see red fringing around objects. It can be drained and refilled with new coolant, but it's gotta be the right stuff. You may be able to get some from a junk set, as I have done with success. Shine a light into the front of each lens. If the liquid has gone bad, you'll be able to see it.
Dec 06, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Toshiba 50H81 projection television
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 22, 2008 | Toshiba 50H81 50" Rear Projection...
Misconvergence ?
you need to have it re converged by a professional
Jul 20, 2008 | Hitachi 51UWX20B 51" Rear Projection...
60" Phillips HDTV Rear Projection
You need new convergence ICs two of them numbers STK392-110 they are available at the following link and they provide free installation instructions with pictures as well as free online tech support while you do the repair which takes about an hour. Heres the link.
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
RCA HD52W56 52" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
