Http://www.microsoft.com/uk/windows/internet-explorer/ go here and download and install internet explorer 8 hopefully this should cure the problem
Try uninstalling a few unnecessary programs
Just run fewer programs or buy additional RAM click start right click on my
computer select properties you will see all imformation about your computer
including installed ram
or
processor upgrades. Your computer is running past its specified limits. But
remember that in this case the blue screen of death should happen extremely
infrequently. If you see the physical memory dump blue screen much more often
then the issue is clearly
on my computer,properties advanced scroll down to system and recovery open
settings write and debugging information the drop down button select none
ideally,
it should already be the default debugger for your system.
The
Dr. Watson debugger program logs all information related to failed processes to
the Drwtsn32.log file. In addition to this, the debugger program can be
configured to create memory dump files related to the failed processes. You can
refer these dump files to analyze the reason behind a process failure.
Perform
the following steps to configure Dr. Watson as the default debugger program to
record user-mode program errors:
The first cause can be fixed rather easily. Simply run fewer programs or buy additional RAM or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly...!..
click start right click on my computer,properties advanced scroll down to system and recovery open settings write and debugging information the drop down button select none
ideally, it should already be the default debugger for your system.
The Dr. Watson debugger program logs all information related to failed processes to the Drwtsn32.log file. In addition to this, the debugger program can be configured to create memory dump files related to the failed processes. You can refer these dump files to analyze the reason behind a process failure.
Perform the following steps to configure Dr. Watson as the default debugger program to record user-mode program errors:
