I recently noticed that the image on my TV is 'zoomed in', in that the image on the TV fills the visible screen completely, but is only showing maybe 85-90% of the image. There appears to be equal proportions cropped off all sides. Is there any way to adjust the bounds of the image so that all of the video content is displayed? I don't see anything in the menus but figured there might be controls inside to adjust this.
If I use the 16.9:1 widescreen DVD mode adjustment in the menu, I can see more of the image on the sides and a little bit more on the top and bottom, but the image is still not complete.
MissNina
That suggestion that was sent to you by Tony Fixit hope it works for you
LtDanNear
Have you tried to adjust your vertical center or vertical size.Hope this helps. Tony Fixit
Missnina
Check to see if your in cinema! if so go to menu wide mode arrow right and down to full.Give that a shot!!
Hi there, you may have a power supply section trouble, check the biggest electrolytic capacitor in the power supply, the rectifier diode, the regulator, and check for some cold solder, do some test, there is a part to be repalced. ty
Get an hd tv try lcd dlp or plasma you will get a better picture
