Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Oct 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does the F20 flashing code mean on whirlpool duet washer
Anonymous
Level 2:
  • Expert 82 Answers
  • Posted on Oct 14, 2009
Anonymous
Expert
Level 2:
Answers
82
Questions
Helped
40892
Points
181
I believe F20 may point towards a control unit failure.
You could try disconnecting it from the mains supply for a minute and plug it back in.
Hope this helps
5 Related Answers
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Feb 26, 2010
SOURCE: What does f20 mean on the duet steam washer?
After a time the small hose that comes from the pump area to the pressure switch located at the top of the machine can clog.
Unplug the machine. Remove the top or the back of the washer. Locate the pressure switch near the top of the washer. It is about 4 in round and has wires and a 1/4 inch black tube attached to it. Pull the tube from the switch and blow through the tube until clear. Reassemble, plug in and test.
Anonymous
  • 15935 Answers
  • Posted on Sep 21, 2010
SOURCE: Whirlpool Duet Steam Washer WFW9600 F20 Error
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) - with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Anonymous
  • 530 Answers
  • Posted on Jan 07, 2009
SOURCE: flashing codes
you have a communication problem between your door lock and your ccu board. Are you hearing a click click click before it fails? If so this is a relay inside your ccu board. Replace the board this will solve your problem
Anonymous
  • 8619 Answers
  • Posted on Feb 08, 2009
SOURCE: F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Anonymous
  • 1902 Answers
  • Posted on Feb 13, 2009
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
1helpful
What does it mean when my duet washer flashes F20?
F20 is a No Water Detect error.
* If you have NO water in the wash tub, check the following:
* If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: Duet_Service_F20_error
Hope helps.
1helpful
What does F20 mean. this us\ally happens during the first cycle.
as far as i can remember f20 means an outflow problem. On whitegoods.co.uk all machine faults are explained. Error codes can be quite vague and f20 could mean your pump has stopped functioning, you outflow pipe is kinked or you have an internal blockage.
The code f 20 flashes on my duet front load washer what does this mean
The F20 code for insufficient water going into the machine. Checked the hoses and water valves at the wall to make sure high pressure water is going to the washer.
You can try a different Cycle water temp setting. Like Cold/Cold or Hot/Hot to see which valve is not letting in the water.
There has been some know failures of the cold water inlet valves. That Whirlpool part number 8540751.
I hope this information has been helpful.
Good Luck.
When the washer is washing a code F20 will flash
take the top of the washer off there is a book in there that will tell you what f-20 is
Getting F20.
“F20” on display
clogged? Are water inlet hoses kinked?Are water inlet hoses frozen?
2helpful
My duet washer has an error code f20...what does this means?
not enough water going to the machine..
“Spin” and “Wash” (HT “Rinse” and “Cycle
Complete”) illuminated or “F20” on display
water supply)
When washing stops and flashes f20
That code means "No water or Insufficient water supply" Check the water supply valve, the fill hose screen for debris... Good luck let me know if that solved it..
5helpful
Hi!
“F20” on display
Thanks
Rylee
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
