This set uses two STK--392-110 ( you can also replace them with STK-392-150 which is a upgrade for the original type convergence chips)----You can buy both on
Ebay
for less than 13 dollars plus shipping.
Both chips need to be replaced
and any damaged resistors around them located and replaced also--most
of the time the set just needs both chips replaced and then adjusted.
If
you cannot do this repair yourself--look in your area--most shops TRY
to charge 300-400 for this kind of repair----I do lots of them
here--did two
Hitachi
sets with this problem yesterday for 200-250 total.
MAKE
SURE WHOEVER you get to do this changes BOTH CHIPS--SOME techs will
come out and just replace one--in a short time the set will have the
same kind of trouble again---Now is the slow time of year for
TV
repair shops---shop around for someone who will do this repair IN YOUR
HOME--almost any good tech can do it in about 1 hour---if they say it
"has to go to the shop" keep looking.
The chips are black(2 1/2
inches wide and about 1 1/2 inches tall with 18 pins) and will have the
STK number printed on them in white--they are located on either one
large metal
heat sink
with fins or two smaller heatsinks that are side by side.
If you have ANY questions or need help reply to this post here.
SD TECH
