Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi 53FDX20B 3D picture
Picture is out of alignment and the magic focus button dint do anything
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
This set uses two STK--392-110 type convergence chips----You can buy both on Ebay for less than 13 dollars plus shipping. Both chips need to be replaced and any damaged resistors around them located and replaced also--most of the time the set just needs both chips replaced and then adjusted.
If you cannot do this repair yourself--look in your area--most shops TRY to charge 300-400 for this kind of repair----I do lots of them here--did two Hitachi sets with this problem yesterday for 200-250 total.
MAKE SURE WHOEVER you get to do this changes BOTH CHIPS--SOME techs will come out and just replace one--in a short time the set will have the same kind of trouble again---Now is the slow time of year for TV repair shops---shop around for someone who will do this repair IN YOUR HOME--almost any good tech can do it in about 1 hour---if they say it "has to go to the shop" keep looking.
The chips are black(2 1/2 inches wide and about 1 1/2 inches tall with 18 pins) and will have the STK number printed on them in white--they are located on either one large metal heat sink with fins or two smaller heatsinks that are side by side.
If you have ANY questions or need help reply to this post here.
I do this here for free so if this has helped you take a minute and give me a vote here.
SD TECH
Posted on Sep 06, 2009
Hitachi 53fdx20b Projection Television Had a convergence problem and replaced both ICs. Resistors checked. Turned TV on and worked but still had convegence problem but not as bad. Waited 30 minutes...
If you bought the parts from sites such as www.TvRepairKits.com go back and ask for there help. It can be many things from bad soldering to blown resistors.
Jun 18, 2011 | Hitachi 53FDX20B 53" Rear Projection...
Won't magic focus
Magic FOCUS button no help all?The tv have a problems known as a convergence problems,it dead 100%.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors it dead too.These parts on the tv convergence board must be replaced to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Dec 08, 2010 | Hitachi 53SBX59B 53" Rear Projection...
51 Hitachi rear projection 6 years old, can't get it to focus, Has sound. Can only get the picture to come in abpout 80%. Around the perimeter, sports scores and subtitels are not readable. Used the fucus...
Flash Focus magic button no longer work.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures problems.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost $300-350 for parts and labors.
Oct 13, 2010 | Hitachi 51F500 51" Rear Projection...
Can't get full screen. tried all aspect selections. also color is off. can't get it to adjust. magic focus dosen't help. any suggestions?
Magic focus button don't work.Colors lines R,G,B mis alignment,have colors shadows picture or 3D pictures.The tv have a problems known as a convergence problems,it dead.The tv convergence board it dead,must require replacing 2 STK convergence ICS and some or all it resistors to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 07, 2010 | Hitachi 57F510 57" Rear Projection...
WHEN YOU PRESS THE MAGIC FOCUS BOTTON IT WILL GO THROUGH THE NUMBERS UNTIL YOU GET TO NUMBER 4 AND THEN IT STOPS. CAN YOU TELL ME WHAT PART IS NEEDED TO GET THE COLOR CORRECT IN MY TELEVISION?
The tv have a problems known as a convergence problems,it dead.Magic focus button don't work.The tv colors R,G,B mis alignment.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Aug 04, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 53FDX 20B: Convergence ...new Sanyo IC's installed
You need to fix the convergence chips 1st.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 31, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Ghosting
This sound like a convergence problem and maybe another problem for the pink symptom. I would not suggest to do it yourself on this one because after the IC's are put in and sometimes a resistor or two there is also a very extensive alignment that could occur. Just off the cuff have you pressed the magic focus button on the front? If magic focus don't fix then the convergence is bad . Suggest a good tv repairman.
Dec 30, 2007 | Hitachi 53FDX20B 53" Rear Projection...
53 FDX 20B Red Alignment
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 20, 2006 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
217 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
