PDF manual URL http://files.mail.ru/CNREX9
Detailed instructions for use are in the User's Guide.
FW780
Operating Instructions
Zfah010e.eps
Read this manual carefully before you use this product and keep it
handy for future reference. For safety, please follow the instructions
in this manual.
RICOH COMPANY, LTD.
15-5, Minami Aoyama 1-chome, Minato-ku, Tokyo 107-8544, Japan Phone:
+81-(0)3-3479-3111
FW780 Operating Instructions
Overseas Affiliates
U.S.A. RICOH CORPORATION 5 Dedrick Place West Caldwell, New Jersey
07006 Phone: +1-973-882-2000 The Netherlands RICOH EUROPE B.V.
Groenelaan 3, 1186 AA, Amstelveen Phone: +31-(0)20-5474111 United
Kingdom RICOH UK LTD. Ricoh House, 1 Plane Tree Crescent, Feltham,
Middlesex, TW13 7HG Phone: +44-(0)20-8261-4000 Germany RICOH
DEUTSCHLAND GmbH Mergenthalerallee 38-40, 65760 Eschborn Phone:
+49-(0)6196-9060 France RICOH FRANCE S.A. 383, Avenue du Général de
Gaulle BP 307-92143 Clamart Cedex Phone: +33-(0)-821-01-74-26 Spain
RICOH ESPAñA S.A. Avda. Litoral Mar, 12-14, 08005 Barcelona Phone:
+34-(0)93-295-7600 Italy RICOH ITALIA SpA Via della Metallurgia 12,
37139 Verona Phone: +39-045-8181500 Hong Kong RICOH HONG KONG LTD.
21/F., Tai Yau Building, 181, Johnston Road, Wan Chai, Hong Kong Phone:
+852-2862-2888 Singapore RICOH ASIA PACIFIC PTE.LTD. 260 Orchard Road,
#15-01/02 The Heeren, Singapore 238855 Phone: +65-830-5888
Printed in Japan AE AE B048-8608
Introduction This manual contains detailed instructions on the
operation and maintenance of this machine. To get maximum versatility
from this machine all operators should carefully read and follow the
instructions in this manual. Please keep this manual in a handy place
near the machine. Please read the Safety Information before using this
machine. It contains important information related to USER SAFETY and
PREVENTING EQUIPMENT PROBLEMS.
Notes: Some illustrations might be slightly different from your
machine. Certain options might not be available in some countries. For
details, please contact your local dealer.
Warning: Use of controls or adjustment or performance of procedures
other than those specified in this manual might result in hazardous
radiation exposure. Two kinds of size notation are employed in this
manual. With this machine refer to the metric version. For good copy
quality, Ricoh recommends that you use genuine Ricoh toner. Ricoh shall
not be responsible for any damage or expense that might result from the
use of parts other than genuine Ricoh parts in your Ricoh office
product. Power Source 220V - 240V, 50/60Hz, 7A Please be sure to
connect the power cord to a power source as above. For details about
power source, P.76 "Power connection"
Where symbols are used on or near switches, they mean an under in
accordance with IEC 60417: a means POWER ON. c means STAND BY.
Copyright © 2001 Ricoh Co., Ltd.
Safety Information
When using your equipment, the following safety precautions should
always be followed.
Safety During Operation
In this manual, the following important symbols are used:
R WARNING: Indicates a potentially hazardous situation which, if
instructions are not followed, could result in death or serious injury.
R CAUTION: Indicates a potentially hazardous situation which, if
instructions are not followed, may result in minor or moderate injury
or damage to property.
i
R WARNING:
· Connect the power cord directly into a wall outlet and never use an
extension cord. · Only connect the machine to the power source
described on the inside front cover of this manual. · Avoid
multi-wiring. · Do not damage, break or make any modifications to the
power cord. Do not place heavy objects on it, pull it hard or bend it
more than necessary. These actions could cause an electric shock or
fire. · Do not plug or unplug the power cord with your hands wet.
Otherwise, an electric shock might occur. · Disconnect the power plug
(by pulling the plug, not the cable) if the power cable or plug becomes
frayed or otherwise damaged. · Make sure the wall outlet is near the
machine and freely accessible so that in event of an emergency it can
be unplugged easily. · Turn off the power and disconnect the power plug
(by pulling the
plug, not the cable) if any of the following conditions exists: · You
spill something into the equipment. · You suspect that your equipment
needs service or repair. · Your equipment's cover has been damaged. ·
Do not take apart or attempt any modifications to this machine. There
is a risk of fire, electric shock, explosion or loss of sight. If the
machine has laser systems, there is a risk of serious eye damage. · To
avoid hazardous electric shock or laser radiation exposure, do not
remove any covers or screws other than those specified in this manual.
· Some parts of the machine are at a high voltage and could give you an
electric shock. Also, if the machine has laser systems, direct (or
indirect) reflected eye contact with the laser beam may cause serious
eye damage. When the machine needs to be checked, adjusted, or
repaired, contact your service representative. · Do not keep using the
machine with a fault or defect. Contact your service representative. ·
If the machine looks damaged or breaks down, smoke is coming out, there
is a strange smell or anything looks unusual, immediately turn off the
operation and main power switches then unplug the power cord from the
wall. Do not continue using the machine in this condition. Contact your
service representative. · Do not put any metal objects or containers
holding water (e.g. vases, flowerpots, glasses) on the machine. If the
contents fall inside the machine, a fire or electric shock could occur.
· Do not incinerate spilled toner or used toner. Toner dust might
ignite when exposed to an open flame. · Disposal can take place at our
authorized dealer or at appropriate collection sites. · Dispose of the
used toner cartridge in accordance with the local regulation.
ii
R CAUTION:
· When you pull out the plug from the socket, grip the plug to avoid
damaging the cord and causing fire or electric shock. · Unplug the
power cord from the wall outlet before you move the equipment. While
moving the equipment, you should take care that the power cord will not
be damaged under the equipment. · When the machine will not be used for
a long time, unplug the power cord. · If you use the machine in a
confined space, make sure there is a continuous air turnover. · Keep
the machine away from humidity and dust. A fire or an electric shock
might occur. · Do not place the machine on an unstable or tilted
surface. If it topples over, it could cause injury. · After you move
the machine, fix it with the caster fixture. Otherwise, the machine
might move or come down to cause a personal injury. · Protect the
equipment from dampness or wet weather, such as rain, snow, and so on.
· Do not allow paper clips, staples, or other small metallic objects to
fall inside the equipment. · Do not reuse stapled paper. Do not use
aluminum foil, carbon-containing paper or other conductive paper.
Otherwise, a fire might occur. · Do not eat or swallow toner. · Keep
toner (used or unused) and toner bottle out of the reach of children. ·
For environmental reasons, do not dispose of the equipment or expended
supply waste at household waste collection points. Disposal can take
place at an authorized dealer or at appropriate collection sites. ·
When removing misfed paper, do not touch the fusing section because it
could be very hot. · Do not touch the anti-humidity switch from inside
the machine because it could be very hot. · The inside of the machine
could be very hot. Do not touch the parts with a label indicating the
"hot surface". Otherwise it could cause a personal burn. · Rolls of
paper can be heavy, so you should be careful when loading one. · This
machine has been tested for safety using this supplier's parts and
consumables.
