You can test the sensor with air, just blow into the tube and it should activate the switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
This means a water pressure sensor. Check to see that pressure hose is
not blocked at tub end nor split. If every thing is OK then replace the sensor, it's Cheap.
Even after replacing that, if the code re-appears, i am afraid to tell you that you need to replace control board.
The pressure switch is located in the top right rear corner of
the washer. This switch senses water level in the
wash tub. The control signal from the pressure switch is
sent to the Central Control Unit and is used to determine the
amount of water introduced into the wash tub during the wash
cycle.
The pressure switch also senses the suds level in the wash
tub. If excessive sud-sing occurs, the washer starts an automatic
suds routine. The display will show the word "Sud".
The automatic suds routine adds additional rinse and drain
operations until the suds level is reduced.
If an overfill condition is detected by the pressure switch, the
CCU will turn on the drain pump and attempt to stop filling.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Thanks for your response!!
With the tub empty, remove the vinyl hose from the switch and blow
backwards through the hose to clear any restrictions. If the fault
codes return after doing this, you will likely need to replace the
pressure switch. and if this still don't clear your code you will need a
new control board i hope it works for you.
Thanks.
Hi
The error code F35 is commonly associated with the Sud error, which comes on within a minute of running any cycle. It means the Analog Pressure Sensor (small plastic electronic circuit) has gone bad. It could also mean the Air Pressure Tube from the Sensor has a hole or isn't connected.
Once you get the new Sensor, remove the 3 screws holding the top panel inplace - they are on the backside on the very top. Remove the top and look at the far back upper right corner (looking from the front). There is a small crimson & black piece attached to the metal side wall with 5 blue wires& 1 black wire (pressure tube) attached to it. Make sure there are no leaks or disconnects...if not, then replace with new sensor.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
WARNING: THIS WRITE-UP IS COMPLETELY MY OPINION BASED ON MY EXPERIMENTATION WITH THE EQUIPMENT. TRY ANY OF IT AT YOUR OWN RISK. YOU WILL BE SOLELY RESPONSIBLE FOR ALL THE CONSEQUENCES (GOOD OR BAD EITHER WAY) THAT YOU MAY REAP FROM THE MACHINE YOU WORK ON.
I made the biggest mistake of taking the whirpool WFW9600TA01 from US to India - I had been totally frustrated with the SUDS/F35 issue, absolutely as explained in the question above.
I started as a novice but feel very confident to write this solution now. There are several areas that could cause this problem. Fundamentally, as the water fills the tub, the pressure form the pressure switch is sensed. If the value is not in line with what is programmed, you get this error. This deviation in pressure value can be caused by any of the below reasons.
First and foremost thing I would do is remove (disassemble - note very carefully the assembly and the position before disassembling. You will need to reassemble in the exact same way in the exact same position) and clean all the pipes, hoses and connectors
Details:
The problem could occur because of:
1. True suds formation due to wrong soap usage (pretty often the problem) - Solution for this? - use a lot of vinegar and a few "risnse and spin" cycles with out any clothes in the washer
2. The pressure switch could have gone bad. Solution - replace the pressure switch (I would do this the last though)
3. There could be dirt collected at the water inlet. Solution remove the water inlet and clean the cup shaped strainer
4. Your outlet/drain pump (the one that pumps the water out of the washer into the drain) may have worn out, there by not draining out all the water. This will leave residual water impacting the next run. Solution replace the pump assembly
5. There may be particle collection such as coins pens, small pins etc in the darn pump inlet strainer causing the drain pump to not work properly and in turn causing SUDS/F35. Solution - remove the front of the drain pump inlet and remove the particles and restart.
6. There is a conical shaped connector connecting the outlet of the tub to the inlet of the drain pump. At one side of this connector (the broader side connecting to the tub) there is a plastic ball in it. If the ball is punctured, water may have collected in it causing it to weigh more than what it is supposed to. When the drain pump runs, the weight of this ball may counter act to not allow proper draining of the water. This residual accumulation of the water will cause SUDS/F35 in the next cycle. Solution - replace that flexible connector. Atleast drain the water from the front at the drain pump inlet, if you want the washer to work for that cycle.
7. There is a small white plastic tube at the back which runs a black tube to the pressure swtich. The assembly is pretty interesting. It is a simple insertion with the air tightness being achieved by a simple rubber gasket covering the insertable part (do not know why the design is such). After a few washes due to the vibration generated by the tub during wash, this gasket can move causing air leaks. Such air leaks do not cause any issue to the current run, but will result in a SUDS/F35 in the next run. It will remain so for al the next runs unless it is re-inserted properly. Solution for this? every time open the rear and make sure the plastic white part is pushed in well.
8. There are other reasons like the main control circulatory / mother board could have gone bad etc. You can figure if this is the problem by running the diagnostic tests for the most part - there is a good chance that only a certified technician can tell you. Solution - replace the mother board (quite stupid huh!!)
9. Finally, the steamer assembly could have gone bad - Although the manual says this, I cannot quite figure out how this would affect the pressure buildup in the tub - I do not know what to do. More than likely if you invite a technician, the person might ask you to replace this assembly.
Try everything - the net effect should be that you have plugged all air leaks. I know some expect to see water leaks at place where air leak exists. That may not be true at all. Good luck with everything.
Can I disconect the pressure switch/sensor and blow pressure into it and ohm the switch?
I went to Sears to buy the cheap pressure sensor and it is $98.00 and takes two weeks to come in. I tried another appliance parts distributor who told me that they have six of them on back order and their other stores all have back orders on them as well. I hate to start replacing parts without some kind of assurance that this is the cause of the problem. If Sears repair service comes to diagnose the washer will they have a diagnostic tool that tells them to start with the pressure sensor or do they also just start with the most likely cause and change parts until they eliminate the problem? I priced the control board and it's cost was $241.00. There are actually two separate control boards but both are over $200.00. Do you know of any way to check the pressure sensor other than spending the $98.00 and hoping for the best? My wife has reminded me to include in the list of problems this washer has is the fact that the softener dispenser puts the fabric softener into the initial wash fill instead of the rinse. I don't know if that is a part of this f35 code or a separate problem all together. The softener dispensing into the the initial fill is not new and actually started long before the code f35 problems if not from the first use of the washer 13 months ago. Thanks for the help.
