Epson Stylus 680 InkJet Color Printer Logo
Posted on Sep 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Middle of three buttons permanently on red - Epson Stylus 680 InkJet Color Printer
Anjazmoro Wicaksono
Level 3:
  • Epson Master 511 Answers
  • Posted on Sep 28, 2009
Anjazmoro Wicaksono
Epson Master
Level 3:
Answers
511
Questions
0
Helped
269445
Points
1600
Did you mean ink light permanently on? See status monitor. Is all chip (ink tank) recognized? Or may be some chip reach "ink out". Try to use another ink tank (new). If you wish to refill used ink tank, you must reset ink counter first.
Tv shuts off quickly ( 1-2 seconds)
2blink-then 4 blink---------vertical circuit problem
This is a general answer based on error code--problem in vertical circuit then the first thing is to look for ANY signs of Glycol having leaked from one of the picture tubes onto that area of the board.
If you do not know how or what to look for let me know and I will explain.
Vertical circuit deflects picture from middle to top and middle to bottom of screen; if set detects that it shuts set off instantly to prevent a instant BURN MARK from happening on all three tubes this set uses--prevent permanent damage to the screens of the tubes.
Picture freeze and pinstrip on the screen
When a Microsoft Xbox 360 console experiences a "general hardware" failure or "core digital" failure, three flashing red lights appear (known as the "Red Ring of Death") around the power button, in lieu of the four green lights indicating normal operation. Warning signs may include freeze-ups, in which the screen has strange, spontaneous graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, the sound is frozen and changed to a strange, static-like sound, and the console only responds to pressing the power button to turn it off. These events may happen once or several times until the general hardware failure occurs, when the user attempts to turn the console on, and the three red lights are seen and the console will not function.
this sounds like it will error e74 which will need a reflow
but dont overheat with a towel as this will cause more problems
My ps3 turned off in the middle of a game and now it wont turn on?
there are also 2 SOLUTION
OPTION 1
You can contact Sony for a repair/replace.
Wait time: 4 - 6 weeks
Price:
in warranty $0
Out of warranty $150/$200
OPTION 2
You can repair the error by your self with the help of lightsfix repair guide.
Price: $37
You can find a great PS3 lightsfix guide Right here
That's everything you need to get this problem
like :
Inside this digital all-in-one set you will learn: check.jpg How to permanently fix the Blinking Yellow Light of Death (YLOD) check.jpg How to permanently fix the Solid/flashing Red Light check.jpg How to permanently fix the Flashing Green Light issue check.jpg How to permanently fix the 3 beeps issue check.jpg How to permanently fix the Red Screen check.jpg How to permanently fix the Black Screen of Death check.jpg How to permanently fix a Freezing Screen (during game-play or during the menu)
check.jpg How to permanently fix the HDMI issue on your PS3 check.jpg How to permanently fix the DNS error issue on your PS3 check.jpg How to permanently fix the No Power issue on your PS3 check.jpg How to permanently fix the Audio problem on your PS3 check.jpg How to permanently fix your PS3 Controllers
and good luck
3 round dots on screen yellow red blue
I have to be honest with you, I suspect the marks are burns on the three picture tubes and permanent.
A simple way to prove this that requires no technical knowledge:
Remove the back cover and locate the three large lens (red, green and blue tubes) and with the set on cover each lens one at a time; if a mark vanishes that tube is burnt in the middle.
If you have three dots or tear shaped marks the set arced and burnt a small area of each picture tube's screen.
These tubes are about 4x5 inches at the screen and are like a regular tv screen; there is a phospher coating and if the set arcs it will burn the coating away in the middle of the screen on each tube.
Confirm this and if true two things would have to happen: replace all three tubes (not worthwhile) and find what caused the arc.
I do not like to give people bad news but I am honest and if this input helped or informed you give this solution a "very helpful" rating as I do this here for free.
If you have ANY questions or need advice do not hesitate to post a comment here and I will respond.
REGARDS, SD TECH
3helpful
2answers
I have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error...
By deepak_compu on Oct 06, 2009
i have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error show,but print not come. and when i print a test page from printer button it gives print. but on paper write like this toner exhoasted so what i do for this problem please give me soltuion of this problem
2answers
I have the 450x Sony Digital zoom camcorder and I'm trying to find the on switch? I see a red button, but I'm not sure if that is the on button.
Your switch is under the lens on the right hans\d side when looking from the front of the camera . It has three positions :
Camera (on position for recording), off(in the middle), and play(on position for playing back your tapes)
My xbox 360 has three red rings and one green in the middle
the 3 red rings are the worst and there is no way to fix it, i tried wrapping a towel around it and leaving it for an hour or so and that worked for me... the is a good old xbox remidee, but if that dosnt work then call the hot line and you will have to send it off.. the usually have it back in about a week
thanks, max
How to hook up the outlet plug on the hot point dryers
white always goes in the middle!!!!!!!!!!!!!!,green on top on green screw,black on one side and red on a four wire outlet,on a three white in the middle!!!!! black on one side and red on the other-mike
2answers
Wirelass switch
Hi, on the 2030 model there are three Application buttons on the right Left button = email, middle = internet, right = WLAN. It may be the same on yours.
Reddish hue on monitor
just switch it off and swith it on
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
