20 Most Recent Sony KP-53V75 53" Rear Projection Television Questions & Answers
If it is fading on all screens (menus included) then it is the picture tubes. If it only fades when source is played, it is the tuner electronics.
Sony KP-53V75... | Answered on Oct 30, 2013
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem as shown below. Doing so will only make things worse.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Sony KP-53V75... | Answered on Jun 12, 2012
michael_tede,
You state that there is a problem with the unit. Knowing that, it would not be worth more than $50 to $100 and only to someone who thinks they can repair it. If you don't want to fix it and want to get something for it, your best option would be to dissassemble the unit and sell the separate parts on ebay. Doing it that way could net you as much as $500 to $1000. Good luck with the sales. I have a tip at http://www.fixya.com/support/r6981868-replace_circuit_board_in_modern_tvs which might be helpful for removing and handling the circuit boards,
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Sony KP-53V75... | Answered on Feb 27, 2011
everettewing,
We do not sell parts but I can tell you where to find them. If you broke the entire screen you will need to purchase three separate screens. Projection screens are made in three pieces and laminated together. The parts you need are available at http://www.encompass.com . The fresnel screen part #4-084-702-02 ($125.00), Diffusion Plate part #4-070-525-01 ($151.00), contrast screen part #4-081-065-01 ($125.00). Freight could be between $45.00 and $150.00 due to the parts being oversized. I have a tip at http://www.fixya.com/support/r6210638-replace_broken_projection_tv_screen which explains the repair/installation procedure.
hardrocko
Sony KP-53V75... | Answered on Jan 27, 2011
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sony KP-53V75... | Answered on Jan 13, 2011
A double pcture with two different colours??? more seriousely the rainbow effect could be of an appature grill un hooked in one of the three tubes (THIS IS DANGEROUS IT COULD IMPLODE) you should have a proffessional looke at it and you should NOT USE OR MOVE the TV until then.
Sony KP-53V75... | Answered on Jan 04, 2011
hello my name is rico, I work on tvs sometimes. it looks like you have cold solder in your boards, probly a regulator is going bad, This kind of work require a tech repair. Take it to a shop where they do free estimate, so you dont loose anything, ethier fix or not. But look for cold solder inside the board , onthe bottom , if can if dont take to the shop, save the headache, if need more help with your tv please fee free to call me at anytime. 602-810-7149 i live mesa az. good luck..
Sony KP-53V75... | Answered on Dec 29, 2010
THERE WILL BE A BUTTON ON THE SONY REMOTE THAT SAYS PIP OR LOOKS LIKE A TV SCREEN CUT IN HALF WITH A LINE DOWN THE MIDDLE.
Sony KP-53V75... | Answered on Dec 17, 2010
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Sony KP-53V75... | Answered on Dec 15, 2010
This is a very common probem on all projection TV sets. Not just sony. Your convergence IC chips and related parts have failed due to normal wear and tear. One common symptom when this occurs is your TV will look 3D and convergence won't adjust correctly. A repair shop will charge around 250 - 400 for the fix. Or you can get the parts and do it yourself. You can get complete parts and instructions from sites like www.TvRepairKits.com or if you know how to do these repairs you can gogole the parts and forgo the instructions.
Hope this helps a bit,
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alingments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK comvergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost like $300-350 for parts and labors.
Sony KP-53V75... | Answered on Nov 22, 2010
This is very common for these types of TVs. Has it recently been moved or bumped? Or possibly exposed to a surge. - READ Warning below.
This is an issue with the color guns being out of alignment. This will require a TV expert to fix. The color guns are controlled by wire field coils wrapped around the CRT or main picture tube. Possibly the glue used to hold them in place may have let go some. I kinda know what to do, and I find it very difficult to do a good job of aligning the guns to produce a clear picture. Take it to a TV repair shop or have them come out to you would be better, because once aligned, it may shift again while being transported home.
WARNING. There are VERY high voltages in back of your set. In the 40 thousand volt range or more. Don't mess with it yourself unless you KNOW what you are doing. Don't guess.
For the money - I'd look at a new flat screen.. !!!!
Sony KP-53V75... | Answered on Nov 09, 2010
Sony KP-53V75 53" Rear Projection Television Logo
76 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
no picture wont come model kp 53v75 rear
  • Televison & Video
