There are two little black components towards the left front of the circuit board as seen from the rear of the set with the brown cover removed. They are labeled F850 and F851. They are actually 5 amp fuses. Both went open at the same time so I jumpered them with two seperate jumpers and it worked the next time I plugged it in and turned it on. Be sure to remove power to the set before sticking your hands in here. The inside of the TV says they are Type SSTR by SOC Corp. Now I have to figure out what to replace them with....
Jim
Unplug TV for 5+ minutes then plug back in ... might work but this usually is caused by some other internal problem that may require service.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
