Have a GE microwave model JVM1430 that has error code of F-3 keypad. Can this keypad be cleaned versus replacing
F3 on a GE / Hotpoint
microwave means you have a shorted membrane keypad.
So until it is repaired,
please leave it unplugged or leave the door
open.
On these models, the membrane keypad is not available as a separate part,
so you would have to order the control panel frame assembly which comes
with a new keypad.
It is usually called the "Control panel asm" in the parts list (ref # 105 on the exploded view) .
You simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Hi
F3 error in your GE microwave
means that the keypad/touchpad is bad and should be replaced. However, before
replacing it you can follow these step by step instructions to clean the
touchpad assembly and see if it works:
1) Unplug microwave
2) Remove two small screws from upper face plate
3) Remove screw on upper side of control panel
4) Life panel and pull out
5) Identify flat tape-like harness connecting
circuit card to keypad
6) Wipe down harness with an all-purpose wipe
7) Use hairdryer to dry remaining leftover
moisture
8) After this put the keypad back
if its not solved then replace it.
Hope this helps...please post back
for further assistance.
Daniel
Here
is a tip that will help you to figure out what is wrong with your
Microwave Oven....
Basic Microwave
Oven
Troubleshooting Tips
heatman101
