Tip & How-To about Microwave Ovens
Microwave Oven Basic Troubleshooting Tips
If you are having problems with your Microwave Oven not working then you need to systematically go through these troubleshooting tips to figure out exactly why your Microwave does not work
The main thing to remember about microwave ovens is that they have large electrical capacitors inside them that can discharge lethal amounts of current even after they have been unplugged. Touching the wrong wire(s) inside, even after unplugging the unit can still be deadly. Make sure that you know how to discharge the capacitors or have a certified repair technician work on your oven.
The most common problem for the oven to not work at all is that the internal (thermal) fuse has blown. This fuse is there to protect both you and your appliance. It will be a simple fix for an experienced technician.
The door switch is another common problem. This switch is activated by the latch, and if it is broken the switch will not allow the oven to work.
If you can hear the oven running and it sounds normal but there is no heat then there is an internal problem with the high voltage circuitry or you may have a problem with the circuit board. Changing the circuit board or the high voltage components is something that you want experienced hands to do.
If it does heat but the power level will not change, then there is something called a triac (electronic voltage controller) that has failed. This also is a job for a qualified technician.
If the turntable stops turning, this is usually caused by the failure of the small motor that spins the turntable. This does not effect the heating but to replace this motor the cabinet needs to be open which will expose you to the hazards of the high voltage components. It is best to seek help to do this.
Intermittent heating problems are often caused by steam making condensation of the electronic components or a loose connection in the circuitry. If it is moisture the circuitry will dry out and work after some time. If it is a loose wire then it will need to be fixed by a technician.
If your unit microwave runs but is buzzing very loudly, then you have problems with the magnetron, the high voltage capacitor, or the power diode. These components are all high voltage components and need to be treated with great care. A good technician knows how to diagnose and repair them safely.
If you observe sparking inside the microwave, turn it off immediately. This can be caused by metal inside, or can also be caused by excessive food or liquid buildup. If it causes any burn spots you will need to have then repaired or fix them to have a safe appliance.
This will give you many of the basic causes for problems in a microwave oven. As you can see there is very little that an untrained person can safely do to repair this appliance.
This can however give you some idea of what to expect if you need to call a repair technician to work on your appliance.
Microwave Ovens Logo
My Microwave stopped heating today but everything else works fine. Any idea what the problem might be? Thanks.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
Jan 09, 2011 | Kenmore 62702 Microwave Oven
Everything works on my microwave but it want heat anything. Lights, Vents, and Fans all work properly. There are no weird noises or anything, whats the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Whirlpool WMH1162XVS Microwave Oven
kenmore combo microwave rangehood.everything works but won't heat food.what do you think the problem could be ?
heatman101
Aug 30, 2010 | Kenmore 62622 Microwave Oven
My microwave oven (Sharp R-9h58) is not heating offen
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
jhfkj
Jun 17, 2009 | Sharp R-1480 Microwave Oven
211,067 people viewed this tip
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
