Check for a cold water supply problem, since cold water is what is used in the rinse cycle. Check the water inlet valve (pay special attention to the cold water side). Unplug the machine, turn off the water, and remove the water supply hoses. Check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will need replaced. Very sorry for your trouble and I hope this helped. Best wishes.
My washer is leaking. Help. I washed a throw and when the cycle finished it was still heavy with...
(More)
My washer is leaking. Help. I washed a throw and when the cycle finished it was still heavy with water. I ran it throught the rinse and spin cycle again and the washer leaked. I cleaned up the water and washed a few more items and the same thing happened again. What is going on?
