Question about Jura Capresso Capresso IMPRESSA C9 One Touch Automatic Coffee Center 2Cup Coffee Maker
Jura c9 on out of box start up won't leave rinse cycle and enter heating mode. Checked rotary dial but it seems fine.
Posted by jeffngaby on
Tim5902
You need to be patient and keep pressing the rinse button. I took a few water tanks of rinsing before it clicked over to heating mode. The manual and DVD need to mention this!
Posted on May 15, 2011
Jura Capresso Impressa 50. It doesn't always rinse when first turned on now and that just started. I unplug and sometimes it resets and is fine and sometimes it doesn't.
Rinsing cycle at start up is electronically programmed function. Unplugging is a temporary solution.
Jura will not sell parts or offer any guidance.
I could look into more details to find an answer but the model Capressa 50 is not listed in my Data base.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Dec 29, 2016 | Jura Capresso Coffee Makers & Espresso...
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
Jura ena 3 rotary dial issue
Have you tried completely powering it down, as far as unplugging it from the wall? Sorry if that's stating the obvious, but I'm a computer guy and 9 times out of 10, a 'reboot' fixes the problem.
Aug 04, 2014 | Jura Capresso Jura Ena 3 Espresso Machine ...
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 26, 2013 | Beko Washing Machines
I can't descale my C5
You may need to go into program mode and "tell it" you replaced the filter. We normally do this when we replace water filters in Jura's. On the f60 you get into program and scroll using the water volume dial and push it in to set the changed value.
Hope this helps
Jan 25, 2013 | Jura Impressa C5 Automatic Coffee Center...
Whirlpool imperial 80 won't heat much
That clicking noise is normal. You may have a thermostat problem. It sounds as though it isn't letting the element get hot enough, or cycling the element on/off too often.
May 12, 2012 | Dryers
During initial startup, will not go into heat cycle - stays in rinse and water is routed to the frother.
Under the rotary switch on the left there is a micro
switch which is probably stuck in and it always pressed. That is why you enter
in RINCE directly and also it repeatedly stays at RINCE position.
So first you need to check the rotary switch and try
to slightly pull it out with a thin screwdriver very softly. If this it does
not make any different you need to replace this rotary switch
Dec 26, 2010 | Jura Capresso Capresso IMPRESSA C9 One...
Tray will not insert properly, a flap seems to be lowered
Start up the machine, take insert everything but the used grounds container. The machine will reposition the brew unit. When the machine says "heating", take out the tray and now you can insert everthing with the used grounds container. You can of course run a Rinse cycle if the machine doesn`t start positioning right away.
Aug 30, 2009 | Jura Capresso Impressa F9 Espresso Machine
Jura Capresso Capresso IMPRESSA C9 One Touch Automatic Coffee Center 2Cup Coffee Maker Logo
545 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
