Televison & Video Logo
Posted on Sep 24, 2009
Split screen I have the panasonic home theater system and my dvd player has a split sceen, side by side, same picture. How do I correct the problem
Anonymous
Level 1:
  • Contributor 71 Answers
  • Posted on Sep 25, 2009
Anonymous
Contributor
Level 1:
Answers
71
Questions
0
Helped
10738
Points
95
Just open the menu and go to tv settings then adjust it to interlace mode.or use your component input if your tv has an ability to receive a YPBPR input much clear than an ordinary video.
With some dvds picture is split screen showing the picture on both halves of tv screen, how do I make this a single picture on whole screen?
HI,
Check on thing Go to the SETUP Menu and check is there is any System settings (colour system) on both DVD and TV . Try all the settings available in the colour system setting. As you didn't mentioned anything about Brand and model number of the player or tv. Its not possible to give you the exact solution.
Ajin
2helpful
I have a protron dvd pds 2315, hooked up to a Insignia LCD HDTV, the sceen is completely pink when I turn on the dvd player. I am using the 3 color coded video cable and a regular white/red cable for...
Turn on your DVD player, go to your set up button on the DVD remote, go to TV and select p-scan. It fixed my problem. My screen was all blue before I did that. Hope it works
We have a panasonic sapt550 music dvd player and want to play dvds in Australia-can you help
I Have problem with DVD play. Panasonic DVD home tHeater system SA-PT550. COMES UP WITH F61
Panasonic SC-PT460 - Little black box covers half of screen
Can you describe the 'box'? Is it the top half, bottom half, a little of either? What kind of TV do you have?
I suspect you might be noticing the aspect ratio of the various source programs being presented differently on a wide screen than you are used to. DVD programs come in a variety of aspect ratios. Normal TV is 4x3, that is, 4 units wide versus 3 units tall. Wide screens are more like 16x9, so a 4x3 image presented properly on a wide sceen would have black vertical bars on both sides. That is normal.
Some people are offended by the black bars and TV's are unfortunately designed to allow gross modification of the image to fill the space. That is akin to taking a photo of yourself and stretching it to fit an improper frame. That probably wouldn't be very flattering to you and certainly wouldn't be accurate. Which is more important - the picture or the frame?
Home theater system, DVD picture freezes
can be a dirty laser eye that can be cleaned with a dvd lens cleaner kit , you can pick them up at any radio shack or electronics store or even wal-mart just go to their electronics dept , most people today own home theater systems and dvd players, and even electronics need to be cleaned from time to time ,so it,s a cheap way of getting the best picture out of your dvd player and it is simple to use ,it looks like a dvd and comes with instructions ,some come with an alcohol fluis that gets put on a little furry brush on the disc ,this brush gets a few drops of alcohol and you put the cleaner disc in the tray and press play , thats all their is to it , thank you for your question if i was able to help you please leave me a nice rating , sincerely glenn mayer
6helpful
2answers
Dvd player split screen
I had the same problem. It turned out to be my cable that went from the dvd player to the TV. I replaced with new cable & everything worked fine again. Hope this helps & please remember to rate my answer. Thanks.
My dvd home theater sound system is saying mode not supported i
the tv HDMI point is faulty becourse i tried it from other point and is working fine, thank you for your concern.
3helpful
I'm not getting any color pictures in my home theater system
Well, assuming were talking about a dvd player with dvd's,you dont specify what type of cables you are using to conect it to your tv, it appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Thanks...
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
