The rubber belt is worn and slipping under load. (like a fan belt)
There could also be something caught in the belt or pulleys; clear it out and it should work.
If worn, replace belt soon...
Hope this helps!
Sounds like the drum belt is worn. That would make a squealing noise and as it slips it could be heating up and causing the smell. Replace the belt. The following site tells how to do it:
http://home.howstuffworks.com/how-to-repair-a-dryer.htm
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
