SOURCE: Dell 3000cn Network Connection not working
First of, the ethernet must be 'on'. If dhcp available, set it to auto (or dhcp.. anyways..) and let it reboot, just in case :)
if not, try setting the IP-setting yourself. They should be somewhat similar to the settings on your local computer(s).
To add the printer to your computer, select 'Local' printer and specify 'tcp/ip' as which port its connected to. In the new window the ip to the printer should be entered. :) (at least for XP this is..)
Hope this gave you the correct solution..
SOURCE: Inspiron 6400 detects networks but does not connect to internet
Make sure you are connecting to your own internet connection through your wireless router and not on your neighbor's.....limited connectivity means you are out of reach or signal is blocked....
SOURCE: i formatted my dell inspiron b120 model laptop i need lan driver
Here is a link to the Network Driver:
http://dsn.us.dell.com/DSNCR/DSNGateway?target=GetDocument&objectID=0E2392E739334481872AE06262A4FC10&languageCode=EN®ionGuid=DD4C7CB26E136815E030A68F27285B52&open=1
SOURCE: Describe your Dell "Inspiron
click to connect with server or you you have exusted all your permit acct with service provider.
SOURCE: 3100cn Laser Printer: dell 3100cn service manual...
This link will take you to a site where you can download the manual for your machine. You will the link on the right side of the page.
http://safemanuals.com/user-guide-instructions-owner-manual/DELL/3100CN-_E
Hope this helps.
